Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Cuts at an angle - Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
    Guru:
  • 509 Answers
It cuts at an angle because the chain needs sharpening. If you want to do it yourself, you will need a 5/32 inch chainsaw file and here is a website that shows how to sharpen it...
http://www.ehow.com/video_4419332_sharpen-chainsaw-chain.html
Posted on May 13, 2010
I am unable to cut 5" baseboard at 45 degree angle
from your last post this information was missing
when cutting at an angle the cut depth is always reduced and the 5" board is too thick
to do what you want the saw will have to be 10" or bigger because when cutting at an angle you are cutting a hypotenuse which is the longest dimension of a triangle
so if the saw cuts to a depth of 5" at right angles the angle cut will be longer because of the triangle effect
Nov 19, 2016 | Saws
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
The saw cuts at a angle, want cut stright2
replace the chain with a new one
saws that cut at an angle normally have blunt teeth on one side of the cut
the sharp side cuts the angle and the blunt side follows
Oct 23, 2015 | Garden
After using anew chaini hit dirt. isharpenit withadifferntanglewillthat make a differencein cutting.
sure will , most saws have different angle cuts to teeth on blade this "angle" needs to be maintained as the "rake" teeth that are behind the cut teeth are set to provide a good way to wipe out cut debris (cut,rake,cut,etc.) this is how chain cuts thru wood , if one changes the cut angle on teeth the rake teeth might not do there job correct and saw bogs and "files" thru wood rather than chips thru wood ,takes longer ,more fuel, more effort , a look at saw cuttings tells the tale , more tiny file sawdust = dull chain --- large Chips and less dust = sharp chain
Aug 26, 2015 | Garden
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not jammed. Seems like a loose connection somewhere but where ? and what
Jun 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
What's the Bank Angle Sensor = 32495-98 function? Regards
The Bank Angle Sensor is a safety feature. In the event of a crash or tip-over, the sensor cuts the ignition to stall the motor.
Jan 06, 2011 | 2000 Buell Blast
I have an old Craftsman 9 inch table saw that will not cut straight. When you set the fence and get evrything ready it cuts at an angle. A 1x4 will not cut straight it always cuts at an angle. Is there a...
unplug the saw then:
turn the saw over or, get under it; there is a long bolt that sets the
saw motor tilt two nuts jam lock it; release the nuts and adjust the saw using a t-square for 90 degrees.
Jul 31, 2010 | Craftsman Saws
How do you tip the saw table to cut on an angle
Hi, usually there is a wheel or knob at the back side of the saw table , with a gage that will tip the blade for angle cuts
What make a model is your saw? I will search for details.
Please Vote !!
May 30, 2010 | Saws
My saw cuts at angle to the right
When My Pioneer did that a close inspection found a wire edge on the top rear and bottom front rails of the bar. A flat file used at 45° to the rail removed it. The bar once again cuts true. The only other likely possibility is the chain is sharpened at different angles. HTH
Lou
Dec 04, 2009 | Homelite ZR10926 16 Chain Saw
Tile Saws for shor and vurved cuts
A 100mm angle grinder is used for that kind of work. It can also be used for "L" shaped cuts and for making holes. It is usually being used dry and more rarely used wet
Aug 27, 2008 | Black & Decker WP900 6 Inch Random Orbit...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
327 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
