I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
Posted on Nov 25, 2010
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
Jan 03, 2016 | Samsung Televison & Video
Circuit diagram for regulator TV samsung plano 29 inch
The diagram is in PDF, It cannot be send to you by this window.
Mar 28, 2013 | Samsung CW29M64NS 29" TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
I have got Samsung Plano 29 inch TV. I see red,green and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
dear hari
i suggest you doing this
HARD RESET: First, do the hard reset so that if there is a corruption of the soft codes, this will reprogram them back to the original factory settings. Just unplug the power cord for 4 hours; thereafter plug it in and power it up.
WHACKING Test: Smack the set with your hand or fist all around the chassis; side, top, back, etc. This will reactivate any loose connection or cold solder joint.
If the above two procedures do not help you should be thinking about purchasing a new set. This one is already near the end of life and fixint it will just add to the cost of owning it. You will be better off with a new tv.
The cause of this is most likely coming from the convergence function; this circuit organizes the video signal and modulates the picture and the raster sweeps to each other so that the picture is properly assembled on the screen for viewing. When it goes out, the entire picture will be effected.
If smacking the set restores the picture, try to find a magic smack, or put a magazine or book under one corner to see if it will put some torque on the chassis to keep it going.
But, the set is too old to put very much money into its repair.
Hope this helps you find the right solution.
thx
Mar 19, 2010 | Televison & Video
Want DEFLECTION SETTING for my samsung plano 29 inch gigabass tv
I need the deflection constant from Samsung factory for adjustment TV Samsunng Plano of me.
Nov 08, 2009 | Samsung Televison & Video
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Samsung plano tv
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Dec 04, 2007 | Samsung WS32Z308P 32" TV
Televison & Video Logo
709 people viewed this question
Top Televison & Video Experts
Electro Med Services...
