Question about Whirlpool Calypso GVW9959K Top Load Washer
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all the trash that was hung around it keeping it from turning. Put everything back together as it came apart and ran machine. It was draining after the quick wash cycle and everything seemed ok but it flashed a sr or something code after it completed and then after putting in another load it started leaking and flashed the ce code. Washer is off and the water is turned off and its still leaking. Possibly the drain motor seals?? and what about the ce code thanks so much Daniel
  • 15,935 Answers
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
The screen on my washer is saying the code LD i dont have a manual and it wont drain completly. I took my clothes out and they were completly soaked with water. HELP! :D
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem
Jan 12, 2011 | Kenmore 22062 Top Load Washer
Will not pump out water and getting CE, OB, and LD codes.
Hello, check the fuse on the motor control board and see if it is blown. If so, You could just have a bad board, but it may be a drive motor or pump motor. The most common thing is for the pump seal to leak into the pump motor and cause a short. The CE code means the 2 boards can not communicate with each other so be sure to check the wiring connectors between them.
Thanks
May 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stopped and flashed Ld. I took out the
Hi
Thanks for using FixYa. Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Starts filling than stops than start filling than stops and a code come up saying CE OR LD
Apr 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Cabrio Washer LD error code
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
For the kenmore elite oasis he top load washer, what does the error code DL mean and how do i fix it
We jamed a straw in the door lock so the sensor thinks there is something in there
Jul 02, 2008 | Washing Machines
Got a LD then a CE error
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
This can be caused by corroded pins on the control card or motor control. Most of the time this relates to a faulty machine control card.
Dec 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
129 people viewed this question
Dan Webster
Dan Webster
Sal De
