Question about HP Compaq nx6310 Notebook
Not powering on
Laptop with old (4yr) batteries, died when i tried plugging AC chord. Not switching on now.
  • 4 more comments
  • Anonymous Apr 17, 2008
    I have problem no power i found ic 4825p out put less voltage (2.2)this ic damage or no?what is the real voltage there?
  • oupamster Jul 01, 2008
    have the same problem; no lights at all when the charger is plugged in. i removed the battery hoping to get power using the charger only, but the machine is dead still. any help? tnx - oupamster
  • demonic0clow Aug 01, 2008
    i have the same problem so i got a new battery and charger but still wont turn on or charge and no lights the new battery i brought was fully charged and the laptop top work so think it must be a fault on the motherboard
  • Anonymous Dec 02, 2008
    same problem i think its a motherboard fault . who has circuit diagram?
  • Anonymous Jan 22, 2009
    4825p should be 19.8V, but its probably a capacitor BEFORE the IC thats causing the problem, unless you have traced it that far already.
  • Ekse May 11, 2010
    when you plug the AC in, do you see a power / recharge led light up on the laptop?
  • HP Master
  • 13,433 Answers
If you need more asistance, let me know.
Posted on Apr 01, 2008
This is a common fault with all HP/Compaq laptops in the NX and NC range, which affects the motherboard. I can fix this motherboard fault and replace all the required components, strip the device down and reassemble it, then fully test the hardware and stress test the entire system for just £50 plus return postage.
If you are interested in this service please contact me on liamcrayden@gmail.com - the average turn around is 5 working days and there is no fee if your laptop cannot be repaired. Note that we have large success especially in the NX6310 and NX6325 ranges.
Posted on Jan 23, 2009
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
My HP Pavillion laptop g61 wont turn on or off. There is no fan running it doesnt sound like it is on but the power button light is on and wont turn off. The screen just stays black. I have tried charging...
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Oct 15, 2010 | HEWLETT-PACKARD Pavilion G61631NR Notebook
Hi, I have Acer extensa 5220 ,it is 1.5 years old...Recently a problem started that when i connect battery to my laptop(AC plug is on) the battery LED on the laptop blinks 3 times orange and turn into...
Borrow a "MultiMeter" and check the VOLTAGE and AMPERAGE output from the battery. Although it's rare for an 18-month-old battery to "die" (or to refuse to recharge), it can happen.
If you try to run the computer _only_ on the battery, without AC power, does it work? If not, replace the battery -- look on eBay for cheaper-than-Original-Equipment replacement batteries.
Aug 02, 2010 | Acer Extensa 5620 Notebook PC
Power goes out whwn I unplug ac adapter
ther must be a short in the plug, get it checked before something goes really wrong
Jun 01, 2010 | Toshiba Satellite M35X-S311 Notebook
Power cord not working
Try unpluggin the power cord and check with battery.
Check whether battery is charging with the power chord on.
Try with a different wall socket.
If this does not help.
Try with a different power chord of the same kind and check whether it works.
If yes, the power chord is the ussue. Best would be to replace it.
else
Try your power chord in a laptop similar kind and check whether the other laptop works fine.
Try juggling the power cord and check whether it gives supply.If yes then check for AC adapter for any damages or cuts. If any is found the contact manufacturer for replacement.
else Main board is the issue.
But before this I would request you to go to the website and check for Updated BIOS and updates for chipset driver.
If any is available then download and install.
Check with your AC adapter if it works, Good, else I would request you to contact the manufacturer for a Main board issue.
They would replace the main board if under warranty.
Jul 22, 2009 | IBM ThinkPad T43 Notebook
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
I have a p35-s609 can not run on AC power, lits in front on,ok battery charges but when dies it will not run on the AC power. Also when you turn off the the button stays blue and you can not start back up...
usually when you have power problems are associated with a dying battery.. have you tried replacing the battery? there's no much you can do besides replacing the battery, getting item serviced (which may cost as much or more than the laptop (if old) or getting a new laptop.
Sep 26, 2008 | Toshiba Computers & Internet
Dell 620 Battery Issues
Chances are pretty good that your battery just needs to be replaced. Over time all rechargeable batteries loose their ability to hold a charge. It's also possible, but less likely, that there could be an issue with your AC power adapter or the charging circuitry inside the laptop.
Best bet would be to find a similar laptop with a battery that does charge and switch. If the problem follows the battery then you need a new one.
Dec 19, 2007 | Dell Latitude D620 Notebook
HP Compaq nx6310 Notebook Logo
633 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
