Question about Dryers
Burner dose not lite everytime - Dryers
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerburner dose not lite everytime - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas burner dose not lite everytime - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip thatburner dose not lite everytime - 2_bing.gifbout this problem...
Dryerburner Troubleshooting2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 14, 2010
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Brinkman Gas Grill Elite dual Sear 5 Burner.
Check the reg sounds like its not giving full rate
Oct 08, 2017 | Brinkmann Grilling
The top burner {broiler} workes OK. The bottom burner doesn't lite at all. Both glow plugs [liters ] work fine.
ould be the thermocouple or sensor senseing the ignition. more info would help
Feb 12, 2013 | Kitchen Ranges
The pilot lites always comes on but it still dose not always heat up the oven you have to play with the dial. Its a magic chef oven.
Try tapping the pilot burner a few times with the end of a butterknife to dislodge ash and dust
Jul 14, 2011 | Ovens
The LCD screen for the duplicator go blank after power is switched on. The condition persist for a long time without any change/improvement. The unit cannot function.
before remove all the power plugs to all dvd drives and just let the controller plugged to power dose it works the display if yes try to connect one by one the drives and check the controller display till its ok and then may be one of the drive is defective.if still the same try changing the powersupply .
thanks
Dec 14, 2010 | Lite On Dupsonic 52X 1 to 11 CD Duplicator...
Burner doesn't lite up
I must assume that the unit uses manual controls for the burners.....if the orifice feeding the burner is plugged (some sort of spill) the gas will not reach the burner for it to light. If it is just one burner, I would investigate a plugged orifice feeding that burner.....if it is all the top burners, there may be a supply problem. let me know what you find.
clarkco
May 09, 2009 | Kitchen Ranges
My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Dryers Logo
Top Dryers Experts
