Question about KDS K717s 17" LCD Monitor
Kds 700p monitor
I have a kds 700p monitor .it well turn on for about 30sec. Then goes off .it does this every time it is turned on.would appreciate any help you can provide. Thanks Mike
  • 11,361 Answers
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 13, 2010
  • a_d_kirkwood Dec 07, 2010
    Thanks for the explanation. I opened the monitor and sure enough, all 7 of the capacitors on the power supply board were bulging. I replaced them and it powered up just fine. Cheap fix.
  • Bud Martin
    Bud Martin Dec 07, 2010
    Thank you for this feedback, this will help other people with the same monitor as well.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • KDS Master
  • 848 Answers
Kds 700p monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 170DTLAPH PI 170DTLA 200 000 170DTLA AH 860 AB0 170DTLAPH Power...
Posted on Jan 03, 2015
2 Suggested Answers
skotkolr
  • 558 Answers
SOURCE: Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Posted on Apr 29, 2010
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
I need the 15pin/28pin cable for my kds 700p monitor , where can I find one?
The most likely place to find one is a computer repair store.
Mar 18, 2012 | KDS 17" .25 XF7I Monitor
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Mar 19, 2010 | KDS K717s 17" LCD Monitor
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
My kds usa lcd 700p monitor use to work for like 10 seconds then go black and now it doesnt even turn on led in front doesnt even light up i put a volt meter to it to see continuety everything is good...
Do you get the 5vdc for logic circuits and 12~18vdc for the inverter circuits. Please recheck your soldering works, make sure the caps are installed with correct polarity. See some of my examples here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | KDS K22mdwb LCD Monitor
Monitor does not want to come on
Twelve years is a lifetime for a monitor.
May 15, 2017 | KDS 17S 17" Monitor
Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Can my KDS (#K717S-700P) monitor be wall mounted?
This monitor can be wall mounted but I do not know what bracket you would use.
If you look on the back of the monitor you should see 4 indents in the sticker near the corners. If you don't then rub around near the corners of the sticker. With a sharp knife or pin you should be able to lift out these tiny stickers. You need to measure the distance between these on the horizontal, vertical and diagonal then you should be able to ask somebody at your local TV dealer for help locating the correct bracket.
I'm sorry i can't be more helpful.
Nov 24, 2008 | KDS K717s 17" LCD Monitor
KDS K717s 17" LCD Monitor Logo
489 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
