I have a washer that has been in storage for about
I have a Kenmore elite washer mod. # 110. 16922501 that has been in storage for about 4 years. It worked perfect. I hooked it up and it filled with water but that was it. Nothing happened so I tried it in all the setting. It wouldn't spin or adjitate. Do you know what it would take for repair?
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.16922501&pathTaken=partSearch
If you cannot hear the motor trying to turn, it could be the Lid Switch:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the washer works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide as well as component testing procedures.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
If you can hear the motor trying to turn, it's possible that after 4 years, the rubber center piece of the Motor coupler has worn / deteriorated: If it will drain this is the most likely cause.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Beyond those two basic (they are the most often causes of a washer filling but not agitating or spinning) I'd verify that the motor has power to it.
Posted on May 13, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Catalyst Mod. 22052
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
