Question about Logitech QuickCam Orbit AF Webcam
I get an error message can't initialize plug in directory? I have windows xp
    Problem Solver:
  • 5 Answers
Make sure you have driver installed for that cam
Posted on May 13, 2010
Error 0xc0150002
Hi There,
When you start an Office 2003 program on a Microsoft Windows XP Professional-based computer, you may receive the following error message:
"The application failed to initialize properly (0xc0150002). Click on OK to terminate the application."
To resolve this issue :
  • You upgrade your Windows XP Service Pack 1a (SP1a) Home-based computer to Windows XP Professional.
  • You reinstall Windows XP on your computer.
  • You perform a repair of Windows XP on your computer.
These steps would resolve this issue.
Oct 22, 2010 | Computers & Internet
System is blue screening giving an error meaasge ....registry file corrupt. error 0000146. I am told there may be a hardrive crash...can it be repaired??
yes.
At the Windows XP Recovery Console command prompt (C:WINDOWS>), perform the following steps:
  1. Type the following command:
    cd
    There must be one space between cd and .
  2. Press the <Enter> key to display a C:> prompt.
  3. Type the following command:
    cd system~1_resto~1
    Note the underscore character after the backslash.
10675121.gif NOTE: An Access is denied message may appear. If so, follow the steps below:
    cd windowssystem32config
  2. Press the <Enter> key.
    ren system system.bck
  4. Press the <Enter> key.
  5. Type the following command:
    exit
  6. Press the <Enter> key.
    The system will restart.
  7. Begin again with the first step under Boot the Computer from the Windows XP CD and Start the Recovery Console.
    dir
    Among other information, the dir command will list one or more directories, such as RP1, RP2, and RP3. These directories contain Windows XP Restore Point data.
    Make note of a recently created RP directory, but not one that was created in the past few minutes.
    cd rp<x>
    where <x> equals the restore point data directory number (i.e. RP3).
    cd snapshot
  7. For either error message containing ...CONFIGSOFTWARE:
    1. Type copy _registry_machine_software c:windowssystem32configsoftware.
    For the error message containing ...CONFIGSYSTEM:
    1. Type copy _registry_machine_system c:windowssystem32configsystem.
10675121.gif NOTE: If queried whether to replace the file, press the <Y> key and press the <Enter> key.
    exit
Oct 23, 2009 | Dell Latitude X300 Notebook
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Sep 17, 2009 | Microsoft Windows XP Professional With...
Need file asms to complete installation
The problem is some files in your installation cd cannot be read anymore.
Options:
1. When the error appears try to redirect the wizzard to the directory of your CD ROM and locate the file.
2. If you have back up copy of your xp cd use it to replace the xp cd you are installing when the error appears.
3. If you have a copy of your xp installer on your hard disk re direct the wizzard to that directory.
Apr 27, 2009 | Microsoft Windows XP Professional
Clue finders math adventures says cannot creat directory
I found the answer to this problem. The problem is the install tries to write to files in the c:\Documents and Settings\All Users\Documents directory. For some reason, that directory had lost the ownership. Try searching for "my documents access denied". For XP home, I had to boot in safe mode, then take ownership of the directory. Once I did this, the install could write to the directory and it installed!
Apr 21, 2009 | Learning Company, Inc. Clue Finders Math...
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Itunes
Hey 0836,
If the error message you are seeing reads as "QuickTime failed to initialize. Error # - 2096" you may wish to turn off Compatibility Mode for QuickTime, as doing so may resolve this problem.
You should be able to disable Compatibility Mode by doing the following:
1) Right-click on the QuickTime Player program and choose the "Properties" option from the menu that appears. Normally the application is kept in the C:\Program Files\QuickTime directory, but may differ if you chose to have the program installed onto another hard drive or in another directory.
2) Once in the "Properties" menu, click on the "Compatibility" tab.
3) Uncheck the box that says "Run this program in compatibility mode" if it is currently selected.
4) Click on the "Apply" button.
If QuickTime was not initially in Compatibility Mode, and you still receive an error message prompting you that iTunes requires Windows 2000 or later (or prompts you to make sure that compatibility mode is disabled in iTunes.exe), you may wish to try the following instead:
1) Shut down iTunes.
2) Click on the "Start" menu, then on "My Computer." You can generally also double-click on the "My Computer" icon on your desktop as an alternative.
3) Once in "My Computer," open the drive where Windows XP is installed. Typically this is the C:\ drive, but please remember that your configuration may slightly differ if you have multiple hard drives.
4) Open the "Program Files" folder.
5) Open the "iTunes" program folder.
6) Next, right-click on the iTunes program - this may be listed as either iTunes or iTunes.exe. Once you have done so, choose "Properties" from the menu that appears.
7) Click on the "Compatibility" tab, and uncheck the option to run in Compatibility Mode if it is selected.
8) Click "OK" to accept the new settings.
One of these two solutions should hopefully resolve the problem, but I would strongly suggest visting Apple's support homepage for more information if you are unsure of how to proceed.
http://www.apple.com/support/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 13, 2008 | Audio Players & Recorders
Verify that you have access to that directory
First of all check that you using the administrator account to install and uninstall programs.
you probably changed your permission to Program Files directory.
Nov 08, 2007 | Microsoft Windows XP Home Edition
Logitech QuickCam Orbit AF Webcam Logo
100 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
