Question about Acer AL1916W 19" LCD Monitor
My monitor shows the desktop for about 5 seconds when turned on & then goes black. How can I fix it?
  • 11,361 Answers
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
You need to open it up and inspect the inside, first components to check will be the capacitors, look for caps with bulging top/seal, burnt parts, etc. Pictures will help a lot. See example of failed monitoirs due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 19, 2010 | Acer AL1916W 19" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
