Question about Rainbow E series Canister Wet/Dry Vacuum
Burning Smell Hi, I have a Rainbow E series that when I run the vacuum there is a burning smell. I have cleaned the entire unit and filter but still have the smell? I am afraid that the motor will burn out?
  • 3 more comments
  • okeefe7544 Mar 31, 2008
    Thank you for your help!!!!
  • Anonymous Apr 12, 2008
    My e series Rainbow vacuum cleaner, making loud noise while vacuum. I had checked there is no blocking in the tubing. Please advice what should I check?
    If you have some pictures to show me what to check, that will be great.
    Thank you.
    David.
  • stacnwillie Mar 02, 2009
    My Rainbow model D3C popped and had a burning smell now the motor just hums I can not figure out how to take it apart....HELP PLEASE
  • Anonymous Mar 20, 2014
    A burning smell comes from the vacuum after it has been running for some time
  • Anonymous Mar 22, 2014
    where to buy filter
    President:
  • 1,673 Answers
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Posted on Mar 30, 2008
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
Burning smell
The response by Lynnette is in reference to the power nozzle....if you are having this issue with the main unit, then it could be the armature is starting to go bad. Have your Rainbow in front of you and give us a call. We can walk you through some steps to narrow it down.
www.rainvac.com
800-523-0510
Apr 09, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series Power Nozzle I'm not sure which part of it is not working?
<p>The power nozzle brush roll bearings could be locking up from hair and debris wrapped around them. If that is the case, then the brush roll will be hard to turn and will cause the belt to heat up and give a burning smell. If you need to speak to a Rainbow Specialist, give us a call.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Nov 21, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Smoking rainbow
Give it a decent burial and replace it with a new model.
Nov 26, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
When I turned on the vacuum it started to smell
the vacuum is either shorting or the motor or brush assembly is rubbing something.
Jul 31, 2009 | Rainbow Vacuums
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series smells burnt when power nozzle in use
Replace the belt in the power nozzle, it has to be changed yearly.
Oct 01, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Won't turn on
If there was a smell like something plastic burning it may be that something just actually burned. It does not have to smoke like a chimney (sometimes it does though - depends what is burning)... If there were no strange noises and it did not seem to run any different than usually - most likely the motor is still fine. I would inspect the cord really carefully but to do any more than that you would have to open the unit and inspect everything else.
If you chose to do so – open the Rainbow and hook up the motor directly to a power supply (hold on to the unit as it will move while starting) – if it runs then problem is in wiring. Test the cord with a tester or bulb, then the switch (or 2 switches if this is e-series Rainbow). Make sure all wires are intact. There is not much to test so you will get it done and find the problem quick.
This is messing with electricity and subjecting you fingers to potential hazard by exposing working motor so do it at your own risk and be very careful and if anything goes wrong do not blame me :-)
Aug 31, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
1,117 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
