Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Model KV30Hs510
The TV will not power up, no sound or picture..The standby light blinks 7 times...Have tried leaving it unplugged for a few minutes but still no power..
You just hear the click like it is trying to turn on but nothing, just back to the standby blinking 7 times..Any help would be appreciated.
  • janettt24 Mar 29, 2008
    Sometimes it blinks 6 times, guess really the same problem as 7 blinks right?
  • 790 Answers
Hello janettt24 ,
Yes, 7 blinks indicates power supply troubles. There are several power supplies in this model as well as voltage regulators, anyone of which can be the source of the trouble.
It is usually not a terribly expensive repair, but then I have never seen a repair on a big screen less than $200!
Unless you are technically skilled in tv theory and use of voltmeters, etc., you will need the assistance of an experienced tech (who can identify the problem within minutes
Posted on Mar 29, 2008
  • 59 Answers
Hmmm... per the sony website, you may need to return the telivision for service at this point.
only two things you might still try:
1. make certain you did not plug the television into a power strip: it should be plugged directly into the wall.
2.: reset the television. looks like you already did, but just in case, I'll post sony's procedure here, so you can double-check:
  1. Turn off the television.
  2. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  3. Unplug the television power cord from the electrical outlet.
  4. Let the television remain without power for 60 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  7. Turn on the television.
the sony link for troubleshooting is here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KV30HS510&region_id=1
  • Sony Master
  • 13,433 Answers
Most likely a part inside the tv has failed, and would need to be replaced. Contact Sony, your dealer, or a local professional for a analysis and asisstance or repairs.
There are hardly any magic tricks we could do to make it work.
If you need more asistance, let me know. Good luck.
If someone knows better, please post.
I have a Sony Trinitron 32" TV. The picture don't
Hello
Blinking of standby light in Sony sets are fault indications. You just count the number of blinks occur at a time, by switching the set ON-OFF by its front panel power switch, not by the remote control handset. Just do it for at least three or four times, count the exact number of blinks occurs there, and inform it to me through Fixya. Through the number of blinks, I can locate the faulty section, of somtimes to the exact fault location. Count it keenly and inform me. OK.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv shut itself off while I was watching.
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light...
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Oct 20, 2008 | Televison & Video
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
My 36" Trinitron standby lite just keeps blinking..
Hello Nicrod,
Can you let me know how many times that light blinks on your TV? There would be a small interval between blinks and then big interval.
May 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
