Question about HP Compaq Presario V2000 Notebook
My Compaq Presario 2200 has so many process running how does one know what is valid (needing to run) vs just eating up processes? Sometimes the laptop seems so slow from too many processes started.
    Scholar:
  • 59 Answers
Well there are a couple of reasons for this unprofessional behaviour of your notebook.
It can either be a virus problem or a lot of junk files at times eat up a lof of memory which in turn decreases the performance of the system..
Here are some of the steps which you need to perform to increase the performance of your Pc.
1.At first would request you to download an Anti-Malware Software,here's the link for the same.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Dowload the setup file, save it on the desktop,install the software and then run a quick scan which would definately show up certain infections...
You need to click on Show results and delete them accordingly...
2.After we are done with the Malware Bytes we need to perform certain steps to speed up the system,,
3.Click on Start, in start search or Run type %temp% and then hit enter.
4.This would take us to a new folder, press CTRL+A and then delete everything.
5.Now again click on Start and in start search type PREFETCH and then hit enter.
6.This would take us to a new folder, press CTRL+A and then delete everything.
7.Now open a new browser page and in the address bar type atfcleaner.notlong.com and then enter.
8.Run the file , select everything and then click on Remove Selected, accordingly click on exit.
This should definatly speed up your pc as well as the Numbers of process running would also be minimized and the CPU performance would aslo increase a lot.
Hope this works.
Regards
KEN
Posted on May 13, 2010
2 Suggested Answers
  • 174 Answers
SOURCE: My Compaq Presario 2200 has so many process
Actually if you Google each open process name there are a number of sites that have listings for what each process is/does, if it is necessary, and instructions on how to disable if it is unwanted, like Uniblue's Process Library.
Assuming you are running Windows XP, here is a list of the default services settings. Note this will not include Compaq specific services which may be required for proper function of your notebook.
Posted on Mar 19, 2010
In my compaq presario cq42 has slow process.not working smooth every program...it takes much time to process...how can i solve?
Try downloading and running Advanced System Care and Smart Defrag from iobit.com. It is free and works very well.
Apr 20, 2014 | Compaq Computers & Internet
Connect a wireless printer to a compaq presario 2200
Even though it is a wireless connection sometimes you need to connect it to the printer to set up the wireless function. then follow the instructions for setting up the printer.
Mar 21, 2012 | HP Compaq Presario 2200 Notebook
My Compaq Presario SR2172NX desktop fan keep
Its good to keep like that since PCs need cooling regularly. Not like laptops. Laptops are designed based on architectures which provides cooling internally. Using copper pipes is an example. Anyway there are ways to control the fan speed. Before that check which fan that runs constantly. There are several fans in a system unit. Such as CPU fan, Graphic controller fan, chassis fan, extra coolers. First thing is that you have to adjust your power scheme. Go to control panel and then power options. Select appropriate settings.
If you use Vista as the OS this is a common problem since its visual effects eat the cpu. Specially that side bar and other things and drivers.
Check whether you have a process which is using 100% cpu using task manager. (Processes tab in task manager). If so either you have to stop it or terminate it of its a hanged program.
There are options to control the fan speed in your bios. Check the bios. To enter bios you can use one of these keys. Del, F2, F10 or Esc. One will let you in. Check the fan options and specially for a QFan option. You have to adjust the settings to control the fan. Finally there are hardware controllers which controls the fan speed near the fan (built in to the fan or near the fan's plug on the mother board). You can adjust them if you need to.
Please rate the answer if it helps you to overcome the issue. Thanks for contacting Fixya
May 31, 2010 | HP Compaq Presario SR1503wm PC Desktop
Full format of compaq presario 2100
Most notebooks have a separate partition on the hard drive that holds the recovery media needed to restore the unit.
You can usually run this by pressing F10 during the boot up process. You may need to press it several times in order to get it work.
If that doesn't work, then you will need to contact Compaq in order to order the recovery media kit.
May 09, 2010 | Compaq Presario Notebook
Mar 19, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V4215EA won't boot, switches off by self
sorry dude, this seems like a prone problem on your own PC, this is what you do lete a PC engineer check it out. or if it is still on waranty return it. good luck
Aug 28, 2009 | Compaq Presario V4000 Notebook
Dvd blank burning file problem
please uninstall software and reinstall it agai.
Jul 14, 2009 | Compaq Presario 700 470024-192 Notebook
Task manager problems
get a start up manager program to stop the processes you dont need that will make it not run so much at start up and your computer will run faster and if you try to end one of the processes that the operating system needs it will tell you and not let you do it so just mess around with it and see what you dont need then you can stop it at startup from running
May 30, 2009 | HP Compaq Presario SR1810NX PC Desktop
Lines running along the screen which are permanent
may be the problem cause is heating...
may be cpu fan not working or there is heavy dust on fan..
try to clean cpu fan....
thanks
Mar 04, 2009 | Compaq Presario 2200 (292600-004) PC...
Load needed dlls for kernel
Try running a Windows Repair by putting in a recovery cd you got with the laptop, if not simply reformat and reload windows.
If you need to know how, let me know.
Sep 18, 2008 | Compaq Presario 2100T Notebook
HP Compaq Presario V2000 Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
