Question about Sharp AL 1631 Copier
The red drum light is blinking and it will not make copies
  • 59 Answers
HI drum is reach for end of life thats why drum light is blinking you shuld have to replace the drum or just reset the drum counter to run your machine for another life .
thanks
Posted on May 14, 2010
Red drum light on copier not working
Are you talking about the light inside near the drum (the laser) or the maintenance light?
Jan 13, 2013 | Sharp AL 1631 Copier
You need to have the stater/developer and drum replaced
Mar 19, 2010 | Sharp AL 1631 Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Locked up AL-1642CS with blinking Drum Light
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
Bob
May 03, 2009 | Sharp AL-1642CS Copier
New drum wont work
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Feb 12, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Red paper light blinking
To replace the drum, just pull out the toner cartridge from the front, the drum is the part DR-2025 that is connected to the cartridge. Push down the little purple lever and remove the cartridge from the drum.
Jan 26, 2009 | Brother HL-2040 Laser Printer
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp al-1551
Did you replace the drum with a Sharp brand drum? I recently replaced a drum in my Sharp AL-1642CS, the replacement drum fits ok, and the lights you describe are gone now, but it does make an annoying noise that is new. I wish I would have spent the money to get a Sharp drum, then you can call them directly for support. When I have called them they have been very helpful.
Dec 14, 2007 | Sharp AL-1551 Laser Printer
Change Image Drum light blinking
You have to reset the drum counter. Leave the front cover open Press and hold the "cancel" button until all the lights flash in sequence Close the front cover You should be good fro another 30 - 40 thousand copies. Hope it helps Ed
May 22, 2007 | Dell 1710n Laser Printer
Sharp AL 1631 Copier Logo
223 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
