Question about Dishwashers
We have a matsui mf160 dishwashwasher and it is struggling to get items clean - esp greasy items - i have also noticed it is not hot at the end of the cycle so i think the problem is there is no hot water. What do you suggest? thanks
  • Dishwashers Master
  • 43,501 Answers
Red greasy deposit on door
left over from food washing off of items put inside there?
a food safe alternative to harsh cleaning chemicals is to use white vinegar instead of detergent , it makes a great grease cutter and washes away with no drying agent nesssacary
Oct 20, 2015 | Dishwashers
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
Matsui MF160 door tension is still strong after adjustment. Program cycle takes 150mins
Time consumption depends on the cycle chosen. For a full complete wash 150 mts is ok.
Also check whether water flow to your machine is free from clogging! Check the strainer attched to the water whose connecting junction.
May 19, 2010 | Dishwashers
We have a matsui mf160 dishwashwasher and it is struggling to get items clean - esp greasy items - i have also noticed it is not hot at the end of the cycle so i think the problem is there is no hot water....
The dishwasher's heater is likely shot. Get a new heating element. The same heater drys and the end but also heats the hot water during the wash cycle. No hot water = dirty dishes.
Mar 19, 2010 | Dishwashers
Cleaned plastic cups and bowls have a greasy film on them
water heater temp to low maybe new elements clean internal unit screens cascade complete jel
Feb 04, 2010 | KitchenAid Dishwashers
Matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Matsui mf160 dishwasher salt indicator will no go out
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
AcmeUK
Apr 20, 2009 | Dishwashers
Matsui mf160 deturgnt door wont open
hi The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent the door will not open
Sep 13, 2008 | Dishwashers
Matsui dishwasher mf160
I used the solution I found for a slightly different fault, ( this was the same fault but without the bleebs)
switch off mains and turn off water. Then disconnect water pipe and lay machine on it's back. Switch on electrics, and allow water to run out. Switch off electrics and stand machine up .Reconnect everything and hey presto I can hear two good things, the machine gently humming, and my wife telling me what a genius I am !!
Aug 05, 2008 | Electronics - Others
Matsui MF160 Dishwasher
Unplug the cable and wait for about 15min. and then plug in cable back and turn on.
good luck
Aug 01, 2008 | Electronics - Others
Dishwashers Logo
464 people viewed this question
Top Dishwashers Experts
Owen Barnes
