Repair on Hp laserjet 4250. Printing but smearing black ink on paper
    Champion:
  • 224 Answers
The fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
Posted on May 14, 2010
HP 2600 does not print onto photo paper
change the paper type in the printer properties and try.
Jan 09, 2010 | HP Color LaserJet 2600n Printer
I have a problem with ink smearing on Southland fine linen paper on letters I've sent out The letters are folded in three and put in an envelope. The reciepients are recieving the letters with smeared...
Sometimes it's due to low fusing temperature. Certain papers need higher temps. Check the paper supplier or look in the printer setup menus and adjust the paper type to as close as possible to what you have.
Oct 23, 2009 | HP LaserJet 4250n Printer
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Print smear
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Oct 15, 2008 | HP LaserJet 1100 Printer
INK ON SIDE OF PAPER
i would replace the toner cartridge first.
Feb 11, 2008 | HP 4250 Monochrome LaserJet Printer
260 people viewed this question
jasbo
jasbo
