Question about Dishwashers
Water leaking from bottom left of dishwasher- help please
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 14, 2010
Water left in bottom of dishwasher. Dishes clean. When I pushed START to see if that would empty machine, water started leaking from the bottom. I removed kickplate and leak was coming from around bra
Cathy, you need the help of a neighbour with basic DIY skills. A hose may have perished and started leaking or it needs 2 turns of a screwdriver on a hose clip.. Either way you need help.
Dec 28, 2014 | Dishwashers
I have a five years old kitchenaid dishwasher that leaves water the in the bottom sometimes. I have replaced the drain pump and checked the drain hose for blockage but I still have the same problem of...
Propably you have leak from the main pump impeller seal.See the video below. It helped me to fix yesterday same problem.
http://www.youtube.com/watch?v=RLkMncM6JDE
If you open the bottom of the dishwasher you can see the leak.It leaves calcium at the base of the pump.
Sep 10, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Leaking dishwasher
Check you gasket around the door for cracks, if needed replace it or clean the door around the bottom and see if it helps.
Oct 16, 2012 | Dishwashers
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Plugged in dishwasher and seems to be leaking from the bottow
does it leak when you don't use it? check around the fill valve.
Nov 10, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Leaking dishwasher
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Feb 27, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
Owen Barnes
