Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
There is a leak on my 4 person Dream Maker hot tub at the pumps connection to the other plumbing. I'm wondering if it needs a new gasket or what? The leak is taking out a couple inches every couple days. It's a drip leak and seems to be coming out of the pump where you screw the cover on the pump that is connected to the plumbing for the rest of the hot tub. Anyone that can help would be great. I'm hoping that I only have to purchase the gasket for the pump/hot stick.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
  • I used to teach plumbing.
  • I honestly have not worked on This unit.
  • I would like to SUGGEST using some Plumbers Tape--not puddy to start with. This might fix it w/o a new gasket.
  • If That Does not fix it, go to your Local Plumers supply store (I would NOT go to home depot or lowes; I would go to the old fashioned shop) and get the gasket for the pump, as you are pondering about.
Posted on Aug 12, 2010
2 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: There is a leak on my 4 person Dream Maker hot tub
From your description it sounds as though the wet end faceplate gasket needs replacing. Where are you from? If you're from the UK I may be able to help you. Feel free to contact me: http://hotub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
6 month old jacuzzi hot tub has started leaking intermittently , any help here to solve this problem
remove front panel visually inspect pumps to see if leaking if ok check by control box remove cover inspect where plumbing runs through keep eliminating thing until you find it
Sep 02, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Cant find the leak it isnt coming from the drain or the jets ??
???Might it be coming from the pump face seal ?? that's a very common place to find a leak
Apr 10, 2014 | X-400 4 Person Hot Tub Spa - Dream Maker...
Just purchased a used Dream Maker X400 hot tub. It holds the water during the filtration cycles but if we attempt to use the hot tub by turning on the jets there is a major leak. Is this from one of the...
Have you opened the equipment access door and looked in it while it is running. I would look at the pumps to see if one of the seals are leaking. They will leak more on high speed and if you have a cir pump that runs the filter and an additional pump for high speed jet action it would make sense why it is leaking more while you are using it.
Oct 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Drain pool without draining hot tub
Is your spa plumbing tied into the pool plumbing? What exactly are you trying to do?
Mar 18, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
There is a leak on my 4 person Dream Maker hot tub at the pumps connection to the other plumbing. I'm wondering if it needs a new gasket or what? The leak is taking out a couple inches every couple days....
Regards,
Ian.
Mar 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What size shaft seal is in a dream maker eclipse spa? I need a new one to replace my leaking seal.
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
Oct 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker hot tub keeps needing to be reset at the plug i have to keep resetting it all the time is there another fuse or something i can do
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Aug 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
412 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
