Question about Sampo AlphaScan 411 Monitor
The sampo alphascan 411 has not picture the screen is black. Turns on but no picture.
  • 80 Answers
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
Please help with a LCD TV. I have a SAMPO LME-32X81 and when i turn on, out a few lines on the screen. this happens all the time, I tried changing channels, source (video, TV, cable) Anybody can tell me...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 29, 2017 | Televison & Video
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
I have a Sampo S 1522 and the on/off switch will not always switch off the monitor. I need to press it multiple times to get it to turn off the display. Can the switch be changed? How do I get to it....
Cord unplug, on safe working table.
You have to open the back cover remove some of its screw, swivel base. Maybe some retaining clips. Detached the circuit board for space. Then your at it. Replace the switch with exact replacement. Then cover it back.
Be careful not to bend the board. Also nasty voltages inside it.
Apr 12, 2009 | Sampo AlphaScan 712 Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Screen flickers
check for bent pins on the sub-D connector. flex the monitor cable while its turned on.. a cut wire will yield just a flickr. especially the H and V sync lines.
May 09, 2008 | Sampo AlphaScan 521 Monitor
Please help me.
checked the horizontal output,a big transistor near the flyback trnsformer, if it is shorted replace it,,,,
Feb 13, 2008 | Sampo AlphaScan 411 Monitor
Sampo PME-42S6 W/red lines runnig through the picture
Try using a DVD player with Progressive Scan, it might work fine. I don't know what the problem can be but that's the only way I can see anything.
Jan 08, 2008 | Televison & Video
"No Signal" floating notice on Blue Screen - No other picture
If all connections and the tuner have the same issue, you either have a power supply issue or a bad digital board.
Mar 29, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Screen blanks out
A digitalizing picture is most likly a bad connection on a screen driver cable or the driver itself is intermittant or the power supply has an intermittant filter on the substain B+ line. hope this hellps.
Oct 08, 2006 | Sampo PME-42S7 42 in. Plasma EDTV
Refresh rate
Do you have the right drivers installed for the display card? If not, update them. In addition to you may be using a network in which the administrator has blocked other users from accessing this kind of settings.
Feb 22, 2006 | Sampo AlphaScan 800Y (White) 19 in.CRT...
Sampo AlphaScan 411 Monitor Logo
166 people viewed this question
Top Sampo Computers & Internet Experts
Paul Bade
michael galang
Are you a Sampo Computer and Internet Expert? Answer questions, earn points and help others
