Question about Frigidaire PLD2855RFC Dishwasher
Leaking from bottom middle and right side of door
  • 283 Answers
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
Posted on May 13, 2010
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Apr 22, 2015 | Frigidaire PLD4375RFC Dishwasher
Help 2005 chrysler pacifica heater and defroster blowing cold air.. was nice and hot 2 days ago....... fan showing
Your blend door actuator may have packed up. My manual says you have dual controls--true? If yes, is it cold on both sides?
Remove the silencer from beneath the driver side end of the instrument panel and take a look at the actuators. #4 and #6 are for the blend doors. Can you see if the little axle is rotating when you change the temp setting? If you can't tell, take one off and see if you can rotate the door by hand and get warm air to come out. If not, perhaps you have air in the cooling system. Check your coolant level and refill if needed. Then let's have a discussion about where your coolant may be leaking. OK?
Fig. Wire harness connector (1), mode door actuator (2), screws (3), drive blend door actuator (dual-zone) (4), heater core (5), blend door actuator (6) jturcotte_596.gif
Dec 22, 2010 | 2005 Chrysler Pacifica
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q
Mar 19, 2010 | Frigidaire PLD2855RFC Dishwasher
Dishwasher door leaking
You probably need to replace the door seal part number 902894.
Jan 31, 2010 | Dishwashers
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Freezer leaking and icing underneath
The plug may have been mashed and deformed.
Replace it.
Mar 12, 2009 | Kenmore Freezers
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Frigidaire PLD2855RFC Dishwasher Logo
553 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
