Question about Nextar MA933A MP3 Player
Play button broken
The play/pause button is stuck inside it. I think I pushed it too hard or something. Can it be repaired?
  • 39 Answers
If you want to risk it. Try tapping on table maybe it will pop out. Try using a small screwdriver to make it go flat and then guide it up back into place and Try taking all the screws out and putting the button in thwen put it back together
Posted on Mar 31, 2008
SOURCE:
Cant get it off of the pause feature
press pause button again, wait for it to respond
(make sure door is closed)
if that doesn't work, press and hold pause button until something happens.
if that doesn't work, power off, then restart
if pause is on all the time, and never resets, even after power down/up your button is stuck/broken, fix/replace button or panel.
Jan 01, 2013 | Washing Machines
Alpine cdm 7861 stuck in pause mode
Check for a "jammed" button. They use a little rubber membrane behind buttons and over time they do wear out. It is possible to push a button on the corner, make it shift enough to jam behind the faceplate & hard to see. Just push the button and see if it pops back like the rest of the buttons on the unit. If it still has a problem, post a comment and I will help you some more. Hope this helps
Jun 22, 2009 | Alpine CDM-7861 CD Player
My ipod was put under a pile of books and now it's frozen! Help!
If you hold down the top and bottom buttons ( Think they are play / pause and the menu button down together ) for at least 5 seconds - obviously doing this when the lock slider switch is on the unlock position and it should do a hard reset and allow you to reset it.
If that does not help there are articles on the apple website which will walk you through how to reset it.
If you can do a hard reset via the menu and play / pause button ( holding them down for at least 5 to 10 seconds ) it should start to restart - when its restarting let go and it should request you to select a language and go from there.
Jun 02, 2009 | Apple iPod nano 3rd Generation
Pause button is stuck
hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
regards,
voodoo
Apr 19, 2009 | Emerson PD6870RD Radio/Cassette/CD Boombox
Player gets paused by itself
simple problem.
remoove front panel and clean pause micro push button with cleening solvent.or you donot use this button remoove the button bu usind soldering iron.
the problem is with this the swich contact witout pressing the button because of dirt inside it
nuwan
Jan 09, 2009 | Electronics - Others
Nextar mp3 player button problems
i figured out how to use it without using the play/pause botton by going to browse it plays the song automatically instead of having to press play.
thank you for the help
Jul 28, 2008 | Nextar MA933A MP3 Player
Toshiba tv/dvd combo
is there a tiny little hole you can insert a paperclip into around the front of the cd.
if so use a large one if you have it , insert and press hard to eject.
if not then you will need help.
even if you get it out the eject motor belt is likely slipped or broken.
Apr 28, 2008 | Mintek DTV-233 23 in. TV/DVD Combo
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Won't even turn on?
there is a very mini like hole in the bottom where the usb goes that is the reset just hit it and it will solve all problems
Apr 12, 2007 | Samsung Yepp YP-T7JZ MP3 Player
Nextar MA933A MP3 Player Logo
56 people viewed this question
Top Nextar Audio Players & Recorders Experts
Marvin
Marvin
Robert Graf
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
