Question about Dishwashers
Hotpoint dwt10 eco flashing light water not going
Hotpoint dwt10 turn dishwasher on select program dishwasher start but no water goes into dishwasher and eco light continueously flashing
2 Suggested Answers
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Posted on Feb 24, 2009
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fwd60 eco and intensive lights flashing
Hi, I have a Hotpiont FWD60, the "delicate" lamp has started flashing about twice a second. Any ideas? Thanks, Nick
Mar 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Mar 24, 2008 | Dishwashers
Jan 26, 2008 | Dishwashers
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
