Question about Sentry Fireproof Safe
Low battery We have a Sentry Safe model - A5889 - it is showing low battery but we can't figure out how to get to the battery to change it.
Dont know your model but on mine the battery is located behind the key pad. turn it clockwise and pull it strait out to access battery.
Posted on Apr 08, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Sentry Safe Model A5889
Turn the key pad in an counter clockwise direction and the batteries are right behind it.
Posted on Apr 23, 2008
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Jan 03, 2013 | Safe International Digital Electronic Safe...
Cannot enter into the safe- low battery
If you have lost the instructions that came with the safe, you may have to call a lock smith.
Jan 11, 2018 | Sentry Fireproof Safe
I have a sentrysafe t6 mode i cannot open as battery is dead
Locksmiths install sentry safe batteries this way
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jun 07, 2009 | Sentry Fireproof Safe
Replacement Key
goto SentrySafe.combox..
https://www.sentrysafe.com/customerCare/replacementKeys.aspx
request a duplicate key base on the model and serial number on the safe
Nov 17, 2008 | Sentry Fireproof Safe
Mar 29, 2008 | Sentry Fireproof Safe
Can not open my safe, sentry 3750
Sounds like all you might need is a new Sentry Safe battery pack to hold the batteries. As these sometimes short out from leaking batteries.
Jan 20, 2008 | Sentry Fireproof Safe
How to change the battery of my sentry safe model v260
You must replace the batteries located in under the keypad.
Use a large paperclip to unlock the cover. Push the paperclip into the small hole while at the same time, sliding the battery cover to the right. Gently remove the battery housing and replace batteries. You will have to reset your password again, but can find the directions to do so by going to the Sentry site: http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf,
Dec 25, 2007 | Computers & Internet
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Sentry Fireproof Safe Logo
484 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Ken Williams
Ken Williams
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
