Question about Garden
Briggs & Sratton 15.5hp ohv turbo cooled model 28n707
Briggs & Sratton 15.5hp ohv turbo cooled gas shoots out of tube in air cleaner that tube goes to the side of engine connected to a rectanguler piece when I take that out there seems to be a smallhole in lower right corner
2 Suggested Answers
  • 2468 Answers
SOURCE: Briggs & Sratton 15.5hp ohv turbo cooled model 28n707
this hole gives it vacuum to operate the rubber membrane to operate the fuel pump and the membrant has a hole in it
Posted on Mar 19, 2010
Where is the Oil Drain plug located on a Briggs & Sratton model 128M 05 0012 F1 engine?
I would ck under the lawn mower,should be a square plug above the blade on the bottem side of the lawn mower
Oct 11, 2014 | Briggs & Stratton Garden
Briggs & stratton engine
That being the case...your miss is fuel related. Your mix is too rich..(too much gas...lack of air)...as the tank empties, your mix will lean out, basically telling you what the problem is. I recommend that you first clean the air filter, as this can cause the engine to **** too much gas. After cleaning, if you can tell no difference, the next step would be to adust the car...(air bleed). If this doesn't work, remove the carb soak in carb cleaner, blow out with compressed air, and install a new carb kit, (seals gaskets, and new seat if equipt with a needle valve and float. Good Luck! I hope you find this to be very helpful!
Apr 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Mar 19, 2010 | Garden
17.5 hp briggs & stratton OHV has fire to the plug but not getting gas to plug.
check your filter hoses and lines. then check your carburetor, its problem has a bad needle and seat especially if sat for long time. before installing seat kit flush in tire fuel sys with car cleaner
Oct 14, 2009 | Briggs & Stratton Garden
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Having problem starting and keeping engine running. Spray engine starter fluid and runs for couple of minutes then dies. Acts as if its not getting fuel. It is a 13.5 briggs and stratton engine. Could it...
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
