Question about Dell E173FP (Black) (Dark Gray) 17" LCD Monitor
Monitor blank My Dell E173FP 17" LCD monitor suddenly went blank. The green power light is slowly flashing, rather than staying on. When the power is turned off and then turned back on, the screen flashes quickly and then returns to black. I hooked up a different monitor to the computer and that works well, so I know it's the monitor at fault and not the computer.
  • madhup Jul 12, 2008
    Similar problem, but I could see flicker in screen everytime green LED turn-off. This happened at rate of 1 per minute. Turning-off and restart did not help. Couple of occasion when I slap it on side ( like old TV trick) and it did come up but after couple of minutes later it went on blanking mode. One time when it was stable t access then I changed setting of display never turn off instead of previous setting of 20 minutes. So now I turn-off the monitor (green light) when the system is not in use and so far everything is working! Any idea
    Scholar:
  • 133 Answers
Try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Posted on Mar 29, 2008
Dell monitor E173FP power led flashing green, no video
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Mar 07, 2014 | Dell E173FP 17" LCD Monitor
I have a blank Dell E173FP monitor with the green blinking light. I have ordered and received the repair/replacement parts. Can someone please respond with detail instructions to fix the problem? Thank...
yumaparkie, You mean to tell me you haven't been to YOUTUBE to see all the video clips of Dell E172FP, E173FP lcd monitors being repaired?? Do that first, then come back here if you still need help.
12fixlouie
Jul 15, 2010 | Dell E173FP 17" LCD Monitor
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
My monitor will not come on, I have a green power light
you have a bad monitor or video card call 4 free help 3363926682
Apr 15, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Power almp blinks
i have this problems before its an inverter problem. pls. repair the inverter.
Jun 28, 2009 | Dell E173FP 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP (Black) (Dark Gray) 17" LCD Monitor Logo
250 people viewed this question
Alun Cox
