Question about Sentry Fireproof Safe
Sentry Safe Model A5889
We have the above. A message is showing "low battery" but we cannot figure out how to get to the battery. Can you help?
    Problem Solver:
  • 6 Answers
Turn the key pad in an counter clockwise direction and the batteries are right behind it.
Posted on Apr 23, 2008
SOURCE:
I have a sentrysafe t6 mode i cannot open as battery is dead
Locksmiths install sentry safe batteries this way
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jun 07, 2009 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Feb 22, 2009 | Home Security
Need to reprogram my sentry v360 safe. forgot my code
for instructions use link above.
mj
Feb 21, 2009 | Sentry Fireproof Safe
Replacement Key
goto SentrySafe.combox..
https://www.sentrysafe.com/customerCare/replacementKeys.aspx
request a duplicate key base on the model and serial number on the safe
Nov 17, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Oct 09, 2008 | Sentry Fireproof Safe
Low battery
Dont know your model but on mine the battery is located behind the key pad. turn it clockwise and pull it strait out to access battery.
Mar 29, 2008 | Sentry Fireproof Safe
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Sentry Fireproof Safe Logo
1,303 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
wickedoneroc
Level 1 Expert
ray012965
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
