Question about Whirlpool AWM8123 Front Load Washer
Whirlpool AWM 8125 door lock light starts flashing
Whirlpool awm 8125 When I start the programme it seems to work but after 10 seconds the door lock light starts flashing and everything stops. I have checked the door latch and it seems fine. Can you offer any advice?
chad7houston
  • 62 Answers
SOURCE: Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Posted on Nov 01, 2008
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
Hit it again
  • 13 Answers
SOURCE: Whirlpool AWM 6100/s - stopping
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Posted on Jan 27, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
  • 35 Answers
SOURCE: Whirlpool AWM 8143 - Starts a cycle and then
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
Posted on Jan 25, 2011
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Door ajar light and interior light flash for about 30 seconds after turning car on
well most likecly you have a bad latch, since you do not mention the year, earlier models had a button on the door jam, later models is all incorporated in the door latch, usally if it is the latch, the door don't close with the remove and some times it doesn'h shut properlly.
Apr 22, 2014 | Nissan Altima Cars & Trucks
Whirlpool awm 8103/1
What is the model number of your unit?
Nov 19, 2012 | Washing Machines
Program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
May 04, 2010 | Whirlpool AWM8143 Front Load Washer
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 8125/3 fault code FH
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
Light on spray mode and start button flashes
I came to a solution via another troubleshooting-site. Simply hold the startbutton pressed in for 10 sec's or so. The drainpump starts, but it seemed to never stop. So, I opened the door an tossed in a few cups of water and locked the door. Then it worked fine. Maybe not the most professional way, but what the H.
Aug 11, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
Wont do anything
Maybe door latch adjustment. hold door in at latch and see if it will work
Jan 04, 2008 | Whirlpool AWM8123 Front Load Washer
Whirlpool AWM8123 Front Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal De
