Question about Dometic Rooftop RV Air Conditioner
I have no voltage to my thermostat - Dometic Rooftop RV Air Conditioner
    President:
  • 1,515 Answers
Hi, I am not positive the control voltage to your thermostat will be on a RV a/c, most homes are 24 volts. I know yours would be less. If you have a 2-wire stat and this a/c is not working, take the two thermostat wires a touch and hold them together. Don't worry as this is safe and will not shock you. If the unit comes on and runs, you do have voltage there but the meter may be set wrong. If nothing happens, then you need to find the breaker for this unit to see if it as tripped. Reset it anyway. If still no power, you will need to find the transformer for this unit and check for power to it which will be high voltage/primary and power out which is the secondary low voltage which controls all low voltage controls such as the stat. If you have a wiring diagram on the condenser up top or most RV have a large book that tells you about your coache. If you have a diagram look for the thermostat as it will be labeled in the legend as a T with a circle around it or it may say stat. Follow to see where it gos from there, to the transformer or what and let me know. If the unit does fire when you jump out the stat wires, you will have to replace the stat. Please keep me posted on this. You may have a blown fuse up top cutting off power to the transformer also. You can ohm them out also. Keep me posted so we can solve this.
Sincerely,
Shastalaker7
Posted on May 13, 2010
Why is car heating up aux fan not coming on
Thermostat or fan motor went bad. Check for voltage at thermostat.
If no voltage, check fuse. If voltage heat thermostat with hair driver and check voltage in and out. If voltage there replace fan motor.
Jun 21, 2014 | Vehicle Parts & Accessories
My Nuvo model wine cooling system isn't cooling. The fan is running, but the compressor does not start.
First off, this is high voltage, do not attempt to repair this if you have not worked with 120 or 240 volts!
It may be the temperature control thermostat or the compressor. You will need a volt meter or a test lamp that is rated for the voltage your wing cooler uses. Check the voltage at the compressor (you might have to open a junction panel or box to gain access). If no voltage, unplug your cooler and check with a low voltage battery powered continuity lamp that the temperature control thermostat is at fault by turning it to the coldest setting. Connect the tester across the thermostat and if it does not light the thermostat is at fault.
I hope this helps you!
Mar 26, 2014 | Furniture
Would like to install a new low voltage wall switch to turn our gas fireplace on/off. Understand you can get one in thermostat'. Unit I have seen will fit into existing switch box. Please advise if such a...
Hi Dennis,
Yes, you can use a thermostat to operate the fireplace. To do so properly and safely, you'll need to determine the voltage to the switch that currently turns the fireplace on and off.
Once you know voltage, you would need to choose a heating thermostat (a cooling thermostat would only shut the fireplace off once it got colder) that is rated for a voltage that is equal to or greater than this voltage.
Swap the switch for the thermostat and you're done. Good luck!
Dec 23, 2013 | Lutron Electronic Low-Voltage Dimmer...
P0597 code
P0597 Thermostat Heater Control Circuit/Open
Circuit/System Description
The engine control module (ECM) controls the pulse width modulated (PWM) thermostat. The thermostat controls coolant flow and regulates the engine operating temperature. Ignition voltage is supplied directly to the thermostat. The ECM controls the thermostat by grounding the control circuit with a solid state device called a driver. The driver is equipped with a feedback circuit that is pulled-up to a voltage. The ECM can determine if the control circuit is open, shorted to ground, or shorted to a voltage by monitoring the feedback voltage.
Aug 25, 2013 | 2009 Pontiac G3
LOWER ELEMENT IS NOT GETTING ANY VOLTAGE ON MODEL 65220RS
Short answer: Thermostats may be bad. Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Long answer:
1) If water heater has some hot water, then upper element is good and water heater has 240Volts, and best suspect is burned out lower element.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) If water heater has no hot water because 240volt circuit breaker is tripped on one leg, and only 120Volts is arriving at water heater, then upper part of water heater can appear to have voltage and lower part of water heater can appear to have no voltage.
Open following links for troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more help
Jun 14, 2011 | RELIANCE ELECTRIC WATER HEATER
No deisel getting through so will not give hot water
The fuel solenoid is controlled by two switches, the flow switch or pressure switch and the thermostat or snap switch. These switches are wired in series which makes them relatively easy to test.
First pull the electromagnet off the fuel solenoid valve on the fuel pump hooked to the side of the burner. Slide a screwdriver inside of the magnet and turn on the burner. It should magnetize. If it doesn't you need to pull the electromagnet from the wire it is hooked to and test for voltage. The voltage will be either 12V-24V, 110V or 220V depending on the solenoid you have. It will tell you what voltage it should be on the side of the solenoid. If you have voltage you need to replace the electromagnet. If you do not you will need to follow the wires back into the electrical box.
The next switch you will test is the snap switch or thermostat. It is wired in series to the solenoid wires. If you have a thermostat test for voltage on the outgoing side. If you have voltage the wiring to the solenoid is bad. If you don't have voltage, test for voltage on the incoming line to the thermostat. If you have voltage your thermostat is bad. If not you need to test the flow switch. The process is the same if you have a snap switch however instead of testing the terminals you will test each wire going into the switch for voltage.
Next you will test the flow switch. First test for voltage coming out of the reed switch on the flow switch. If you have voltage your wiring to the thermostat is bad. If you do not have voltage then test the incoming side of the flow switch. If you have voltage your reed switch and or flow switch are bad. If you don't you will need to test your main power switch as the problem lies in the system sending voltage to the burner circuit.
This is a complete test of the burner circuit and should help you isolate your problem. If it doesn't feel free to contact me at 800.247.8103 and I will help you trouble shoot further.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 09, 2011 | Karcher Garden
I want to install honeywell RTH 221 thermostat.Thr thermostat operate 2 AAA batteries. the thermostat remote the heating system selonoid valfs. They works with 220 volts.My question is can I connect the...
If your old stat operated on high voltage ( anything over 24 volts) then the answer is no. However by adding some relays and a transformer you can use that stat.
Jan 15, 2010 | Honeywell Programmable Thermostat Heater
Have a Ruud AC unit the problem I have after installing a new condenser fan motor when I throw the circuit breaker the unit will not turn on but when I push the contacts on the contactor in manualy the fan...
The contactor engages from low voltage power from the thermostat as does the outside condensing unit. You may have blown the low voltage transformer or have a loose thermostat wire. Check line voltage(220 volts) to the transformer. Check load voltage(24 volts) from the transformer. If no voltage out,replace the transformer. If you have voltage out(24) check the thermostat wires and the thermostat. If you have a digital thermostat there is a 5 minute delay in the thermostat after power is restored before it activates.
Oct 08, 2009 | Ruud Central System Air Conditioner
HEATER DOES NOT TURN ON BUT AC WORKS.
- If no voltage output at the thermostat for the supply of heater/reversing valve, then replacement of thermostat is needed (but check the thermostat setting).
- If the voltage output at the thermostat for the supply of heater/reversing valve is present, then then check for heater/reversing valve fuse or overheat protection, and check for defective heater/reversing valve
Jan 03, 2008 | Honeywell Programmable Thermostat Heater
Dometic Rooftop RV Air Conditioner Logo
150 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
