Question about Samsung YP-K3 MP3 Player
Samsung protection mode
Did you find a solution for your protection mode
  • 8,596 Answers
Answer here:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=&dType=D&vType=L&mType=&model_cd=&menu=guides&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K3JAB&isEqualsY=Y#
Posted on Jul 05, 2008
Take out all cd inside your hts and press the stop button more then 10 seconds
Posted on May 26, 2009
Samsung HT2310 in protect mode
If the set go under protect mode, there should be some short circuit inside the circuit boards, of any improper user setting might have happened. Just unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so, and check. This must make a hard reset to the set, and if no other fault is there, it must turn ON. If you wish to get more details about this kind of fault to Samsung TVs., try this link.
Jan 29, 2013 | Akai PDP42Z5TA 42 in. Plasma Television
I have a samsung 55 in tantus digital TV that is in protection mode and I want to know if there is a way to reset it so I can turn the tv on again
Protection mode generally means that there's a short circuit somewhere in the TV and it's in this mode to protect you from fire.
If you'd like the TV repaired, you should contact a local TV repair shop and obtain an estimate. I don't recommend opening the TV up by yourself to correct the short.
Mar 11, 2011 | Samsung Televison & Video
In my samsung champ mobile one message had came in this message the protection mode is on and when I off the protection mode or try to delete the message the phone get restarted
Feb 02, 2011 | Samsung Cell Phones
How do I unlock protected pictures?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Update! I just tried this on a Samsung S630 - hopefully the process will be similar for you (the camera certainly looks the same). You have to be in playback mode. Press the menu button, and go to Playback. Move to 'Protect' and select that mode. You can navigate through the pictures, and on mine, T(elephoto) locks it, and W(ide) unlocks it. In any case, the on-screen instructions should tell you what key it is.
If this doesn't work for you, don't mark it unhelpful (yet) but say so, and I'll find a user manual for your exact model.
Jan 31, 2011 | Samsung S85 Digital Camera
SAMSUNG HT-Q9 displays PROTECT and then switches off?
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.Hope this will help........
May 26, 2010 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Protection Problem on Samsung Digital Home Theater
Bad speaker wiring.
Internal fault.
Regards.
Apr 14, 2008 | Samsung HT-DS610 System
Samsung YP-K3 MP3 Player Logo
1,145 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
