Question about Ricoh Aficio BP20N Laser Printer
How to add Ricoh Aficio BP20 to new laptop - Ricoh Aficio BP20N Laser Printer
  • 903 Answers
Hi, go to Ricoh-USA.com to download the printer's driver software. Go to the Downloads section, choose Drivers, and search for your printer and operating system. Download the driver and unzip it if it is zipped, then go into the Printers section of your computer's Control Panel, click Add Printer, and follow the prompts. Windows will walk you through the installation process.
Posted on Nov 16, 2010
I`m using a PC with win7 and a network printer Aficio BP20 Series PCL 6 its only print in B/W not color why? Need help.
if you are using the proper driver there should be a setting if you click the properties button when you hit print on the computer. from there you can set it to print in color.
Aug 10, 2011 | Ricoh Aficio MP 1600L Black and White...
I need to reset toner cartridge Ricoh BP20
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 15, 2010 | Ricoh Aficio BP20N Laser Printer
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Apr 10, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
I have a aficio bp 20 series pcl 6 printer its failing to print.
Is it only the 'red' light or is there another one also lit?
If it is on steadily, it should be related to a paper jam, if blinking, then related to Data in, and no paper.
Manual is here to check what the status lights mean (copy this link into your address bar):
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/bp20n/bp20nen.htm
** info is on page 6.21
Feb 18, 2009 | Ricoh Aficio BP20 Laser Printer
Add group dial for faxing
you can get the manual(s) here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
Feb 16, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Where can i get the driver for the Ricoh Aficio 3500N
You can download the Windows XP driver from HERE
And the Windows Vista driver from HERE
These are the new PCL 6 drivers from Ricoh.
Hope that helps!
Apr 11, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio BP20N Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
