When I can get Channel 3 on my Sanyo TV, I cannot
When I can get Channel 3 on my Sanyo tv I cannot get Channel 2-3 or 3-4 or visa versa. If I can get can get Chs. 2-3 and 2-4 then Icannot get Ch. 3. I used to be able to set something or other to switch between the two. Could you tell me what do to make it work. Thank you David
2 Suggested Answers
  • 208 Answers
SOURCE: When I can get Channel 3 on my Sanyo TV, I cannot
Hi, check the tv tuning menu for channel 3 - it may have been set to "Skip"
This can be proven if your remote has numeric keypad.
3 will be accessible through this but not through program + or -
Posted on Mar 19, 2010
Trying to connect Sanyo to infinity cable. Can only get 1 channel.
you may be trying to change the channel with the TV remote. The TV probably needs to remain on channel 3, then switch to the Cable remote (make sure its in Cable mode) to change channels.
Dec 14, 2017 | Sanyo Televison & Video
Add a station
This set isn't capable of going over 68, this is all it's programmed for. You will need to get a channel box that overrides the tv's programming in order to add the channel 73.
Aug 27, 2008 | Sanyo DS20930 20" TV
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
Why does my LCD HDTV go to a blue screen when changing channels
if using a box it may be normal but not nice, I would suspect the set is a bit slow reacting to signal change. I remember some nasty JVC sets that when going up or down a channel the screen would blank for about two seconds and come on, normal since all those had that feature(no channel surfing)>
Sep 03, 2012 | Vizio 42 in. LCD TV
Picture to big
Try going into picture setting and reduce the zoom angle or if it's whilst you are watching Sky TV go into System Settings, Picture Settings and change the Aspect Ratio (ie. From 4:3 to 16:9 or visa versa)
Gadget
Feb 21, 2012 | Sansui 19 in. LCD TV
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
When I can get Channel 3 on my Sanyo TV, I cannot get Channel 2-3 or 3-4, or visa versa. If I can get can get Chs. 2-3 and 2-4 then Icannot get Ch. 3. I used to be able to set something or other to switch...
Mar 19, 2010 | Sanyo Televison & Video
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
