Question about Dell OptiPlex GX260 PC Desktop
My hp dc 7600, stop to work and now don't power on. When I press the power button the computer start the fan cool and then turn off.
  • 242 Answers
Big chance you've got a broken motherboard...
Maybe your CPU is broken...
Check your motherboard for 'swollen capacitors'.
Instead of flat, it will have a convex top.
You can also have someone who knows a bit more of computers look after it...
Posted on Mar 29, 2008
I have an old hp v75 desktop that the monitor won't turn on all the lights are working, fan running, nothing wrong with the power supply, but when I press the power button it turns on, but the monitor...
First remove the vga cable from the desktop and see the monitor shows no conection if showing there is no problem with ur monitor if not change the monitor if showing conect the cable back to ur desk to vga port then check the ram remove the ram clean the surface with clean cloth then rub the print using an eraser then insert the ram and switch on if still no display change the ram if still not working remove the processor heat sink na clean th surface of the processor and the heat sink apply a thin layer of heatsink solvent or thermal paste fix the heat sink then restart the computer
Jun 29, 2012 | Computers & Internet
A couple of weeks ago, my HP Pavilion a706n was working completely fine. Soon enough, the first error appeared. I could use it for a good 5-10 minutes and it would shut off by itself. When I attempted to...
If you have cleaned out the dust with compressed air, then I suggest you look at the processor cooling. Is the fan running up to speed? Is the heat sink tightly in place on the processor? Feel the fins of the processor heat sink when you power it up and if they get hot your processor is most likely over heating and shutting down. If all is well at the processor, check the power supply fan to see if it is running and the only other suggestion is to try another power supply. Dust is your worst enemy in a computer.
Aug 14, 2011 | HP Pavilion a706n PC Desktop
Where i can run cooling fan on hp pavilion dv6 laptop 2011 ? i buy new one but i don't no which button i have to press Please help me
It sounds like your cooling fan has stopped and you bought a new one.
The fans are plugged into the motherboard. Your motherboard probably has at least two fan connectors-they are marked "fan" or "case fan" or something like that. There is no button to turn them on. They come on when you start the system.
Jun 03, 2011 | Computers & Internet
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
I want to download audio driver for hp compaq dc 7600 on windows xp. What is the best driver for it? Thanks for help Maz
Audio drivers for this computer are here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=472278&lang=en&cc=us&prodTypeId=12454&prodSeriesId=472276&taskId=135
Original drivers from HP
Nov 24, 2010 | HP Compaq dc7600 Convertible Minitower PC...
I have a dc 7600 desktop when i install win 7 32 bit in to my computer my computer can not reboot and shows black screen can dc 7600 run win 7 or not please ans me
If your PC meets the minimum specifications ie 1Ghz CPU and 1Gb of Ram then it should be able to run Windows 7. You can try repairing the installation by following the instructions below :
  1. Place the Windows 7 installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. The computer should automatically give you an option for startup repair, if not proceed with step 7
  7. In the System Recovery Options dialog box, click Command Prompt.
  8. Type Bootrec.exe, and then press ENTER.
When the repair is done remove the Windows 7 disc and reboot the PC.
Hope that works for you.
Sep 08, 2010 | HP Compaq dc7600 PC Desktop
My hp G60-230US won't turn on
REMOVE YOUR BATTERY AND TRY RUNNING IT OF DC POWER THAT WILL TELL YOU IMMEDIATLY IF IT IS THE MACHINE OR THE BATTERY
Jul 03, 2009 | HP G60-230US Notebook
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Cooling fan replacement for my hp 6624A dc power system
TAKE 9VOLT BATTARY TO SEE WITCH WAY THE AIR BLOWS, UNLESS BY LOOKING AT THE POWER SUPPLY HOUSING AND UNDERSTANDY WHAT THE ARROWS ON THE CACE SHOWS DIRECTION,
DO YOU HAVE VOLT METER, YOU NEED TO TEST TO FIND OUT OUT WHAT 12VOLT + OR - IS ON THE POWER SUPPLY , SOMETIME FAN MANIFACTURE WILL GIVE A CABLE TO PLUG INTO YOUR POWER SUPPLY TO MAKE YOUR FAN TO OPERATE THE RIGHT WAY, IF YOU NEED MORE HELP WITH THIS YOU CAN CONTACT ME THREW THIS SITE
CANDYMANGANDY
Jan 27, 2009 | HP (D6021-63034) Fan Assembly
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Dell OptiPlex GX260 PC Desktop Logo
193 people viewed this question
Alun Cox
