Question about VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - Biscuit
How to fix fill water shooting up and over when flushing?
  • rockscookin May 13, 2010
    Is this a new toilet? Can you see aprox. where water is shooting from? Is there a little fill tube in tank?
  • 349 Answers
Hose in tank it has a clip to secure it to a fill tube in center of tank to let water fill down tube . If it is just stuck down in it or loose it has to much pressure and will spray every where.
Posted on May 16, 2010
Dual flush toilet fills slowly. The fill valve is pushing water cistern seems ok. The fill hose shoots water down overflow tube this is the design. If hose placed tank it fills no problem.
check /replace the small rubber washer at the end of the fill tube as they tend to grow with age and reduce the flow of water past the inlet
Oct 11, 2016 | Home
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
Aug 07, 2014 | Fluidmaster 507C White Flush Valve
When I flush thenwater fills to the fill line and slowly keeps on dripping over the top of the flush valve tube.
I would ckeck to see where water fill line is inside toilet tank and then adjust flush valve to try to get it to shut off at this point. Not knowing whether your toilet still has original flush valve it is hard to tell you how to fix it. If it has float mounted on rod to flush valve there is usually a set screw on the top of the flush valve in the center. Turn this screw clockwise to make valve shut off sooner. Try to set it so that water shuts off when it is at fill mark. If float is mounted on brass float rod you can support rod closest to flush valve with left hand and carefully bend rod down a little with your right. This will cause flush valve to shut off sooner. If the seat is worn to badly in flush valve you will need to replace it.
Nov 18, 2010 | American Standard 2004.014.178 Champion 4...
Water is shooting straight up after flush, then it...
From the sound of your description. It could be the fill tube has come loose from the overflow tube or the ballcock valve has a bad gasket and may need to be replaced. I hope this helps.
May 19, 2010 | Home
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
Mar 19, 2010 | VitrA Aria Toilet with Elongated Bowl/...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
Water shoots out when i flush
either your fill tube came out of the tube in the center that the flapper is connected to or the fill valve wore out.Usually this happens when the little plastic or rubber hose coming off the fill valve comes out of the over flow if you secure it to the center tube so the water goes down it you'll have a dry floor and better working toilet
Aug 11, 2009 | Home
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Cimmaron one piece elongated doesn't have enough water in BOWL.
Make a small mark with a pencil or marker that can be erased of were your water line is in your bowl. Pour some water from a bucket into the bowl SLOWLY and see if the water line rises or drops back down to your original mark. If it drop back to the original mark, then that is the way the toilet was made. You won't be able to do anything about it. If it rises and stays at a higher level, then you have a problem with the fill tube in the tank. You will need to call a Pro!
Jan 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Open Questions:
Water seeping into the toilet bowl Hi Sir/Madam, I have Vitra floor mounted toilets (x3). Currently, one of them is having water leaking problem (water flow to the pan. I believe it is to do with the worn-out washer, but because it was extremely difficult to source the spare parts for Vitra (even through Galvins - the recommended stokist for Vitra products), the plumber suggested me to change the whole mecha nisms inside the tank, and Geberit spare parts was installed after much 'improvisation' from the plumber. However, after a year, the water leaking is backed again. I really want your assistance and instant response to tell me where can I get the genuine parts for Vitra, the entire mechanism in the water tank in order to stop the water from flowing to the pan. I too have a question here: This is the wall-faced toilet suite and the tap water is built inside the tank. Plumber told me also that there are a few fine hair-liked cracks underneath the ceramic/china tank, is it the cause of leaking even though the new Geberit mechanism has been changed a year ago? If so, is it possible to just change the tank rather than replacing the whole toilet suite for other brand whereby parts are easily sourced such as Coroma or Fowler(in the case of Australia) as my toilet is still look new and well maintained (except for the leaking). I desperate want your professional advice to treat this long-pending water leaking problem. Please do tell me where can I buy and/order the parts in Australia. Which country on earch can I order the parts from if none can be acquired in Australia. Thanks very much for your time and assistance in this matter. Kind regards, Angeleen Yong (Resient from Western Australia)
Nov 30, 2011 | VitrA Aria Toilet with Elongated Bowl/...
See all VitrA Aria Toilet with Elongated Bowl/ Flat Tank Questions
VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - Biscuit Logo
261 people viewed this question
Top VitrA Home Experts
jasbo
jasbo
woodzowl307
Bill Boyd
Are you a VitrA Home Expert? Answer questions, earn points and help others
