Question about BaByliss PRO Nano Titanium Hair Dryer
On my babyliss type S47b, special screwdriver???
On my babyliss type S47b one speed doesn´t work. The button dosen´t go to level ii. i need a special screwdriver. But I dont know what kind the type of screw is very special. Never seen it before.
I have a babyliss hair dryer mod. 6619E type S54d The dryer turns on but after a few second it turns off What is the reason.
is it throwing a reset switch on its plug head? if so press the reset button on the plug head if it trips again there's an issue inside the hair dryer thats making it shut off power to it from the plug head
Apr 21, 2017 | BaByliss Dryers
I have a 1991 Dodge Ram 1500 with a 318 engine I cannot find out what transmission it has so after I pulled it I found this set ofnumbers on it D4461106 with this after it 2X with the number 4 over the D44...
The 4 speed transmission electric overdrive is a A500 or A618 old numbers now called a 42re transmission both take the same pan gasket and filters. Fluid type is located on dip stick ATF (7176) sames as dex II/merc ATF plus fluids are a special mix use ONLY that type.
Apr 27, 2014 | Cars & Trucks
Speed up button doesn't work, everything else works good.
1) Check button: clean with special spray (for clean contact) in Radio Schack.
1a) Relais for motor test and clean it.
2) Take measure for a fuse
3)Test Speed Sensor in the motor and calibrate , and replace if necessary.
4) Check the drive motor, and repair( brushes, wiring)
E.CUADRA.
Nov 03, 2011 | Exercise & Fitness
Had my My Book for more than a year. A few days ago my Mac stopped detecting it. I have since change the usb cable, tried the fire wire and it dosen't work
if there is firewire available, try that.
Open Applications
Open Utilites
Open Disk Utility
On left side - see if there is a Western Digital hard drive, there will be two icons for the drive it is there. The drive and its host. the drive may be grayed out. If so then click the mount button and you should be fine.
if the drive doesn't show up there - then try using a pc. also as weird as it may sound. try (if it lets you) flipping the ac adapter in the wall 180 degrees. may be the case if it is not the ac adapter that came with the unit
May 07, 2011 | Western Digital My Book Home Edition 500...
Will jaguar phone work on bluetooth
Not all X Type has the bluetooth device factory installed, even if the radio buttons says so. specially the 2002´s
Oct 09, 2010 | 2002 Jaguar X-Type
Aprilia rs 250 dosen´t run under 3000 rpm. It just dies.It hasen´t been driven a lot the last five years. I put new petrol in so that´s not the problem. And the speedometer dosen´t show...
Over time the old gas in the tank formed deposits. The gas in the carburetors left deposits in the small idle circuit holes. The carburetors will have to be cleaned.
The connector to the sending unit for the speedometer may have corrosion on it. Try unplugging it a cleaning the terminals.
Jul 22, 2010 | 2000 Aprilia RS 250
Speed fun control airconditioned doesn´t work property.
Two possible areas I would check using an ohm meter. First is the blower resistor which is usually located by the blower motor and looks like a cement rectangle or a ceramic tube with wires attached to it. The resistor should have very low resistance but should not read open from the common lead to the other terminals. If it tests good test the continuity of the fan switch. Some cars have a fuse for the high and low blower speeds so you can check your fuse diagram and look for two blower or fan fuses. Good Luck.
Apr 02, 2010 | 2002 Chrysler Sebring
The screw may be triangular, or Torx (star pattern), or even 'pin-in-Torx', which all require special tools. They do it to prevent people from opening them up. But you can buy the tools, and for triangular screws I ground an old screwdriver down to match the shape!
Those screws are called 'Tamper Proof' or 'Tamper Resistant'. If you google those you'll find tool sets that will open dang near anything.
Mar 19, 2010 | BaByliss PRO Nano Titanium Hair Dryer
I can´t reset the modem D-Link 2320-B, I am trying
You can restore the unit to factory setting by pressing the reset button. It is located inside a small hole on the back of your router between the LAN and DSL connections. You'll need a pin or very small screwdriver to reach the button inside the hole.
May 08, 2009 | D-Link DSL-2320B
BaByliss PRO Nano Titanium Hair Dryer Logo
Top BaByliss Dryers Experts
paul
paul
Tom Chichester
Denkichu
Denkichu
Are you a BaByliss Dryer Expert? Answer questions, earn points and help others
