Question about Bosch Nexxt 500 Plus Dryer
My gas dryer is not getting hot i tried cleaning vent and lint trap
  • Bosch Master
  • 43,501 Answers
Hi, If you have a gas dryermy gas dryer is not getting hot i tried cleaning - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
my gas dryer is not getting hot i tried cleaning - 2_bing.gif rel='nofollow' href="http://www.fixya.com/support/t4726170-load_takes_more_one_cycle_dry#">dryer is electric2_bing.gifThere could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gifTroubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 14, 2010
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
MDG850 Gas Dryer: will not get hot
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 09, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
Heats but doesn't dry
If your clothes are coming out hot but still wet you have a vent problem Either the lint trap at the dryer is clogged or the vent coming out of the dryer to the outside has a build up of lint. If you don't clean the blockage it will burn out the heating elements and cause you more problems. A shop vacuum will take care of both problems in cleaning out lint trap and dryer vent
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Gas dryer's not hot enough
make sure there is not lint buildup in the trap or the evhaust pipe, sometines it gets built up in path from trap to vent you may have to take it apart to clean
Oct 10, 2009 | Dryers
Dryer shuts off on E-1 code..Lint trap has been cleaned as well as vent hose and vent riser to outside.
Check for brisk air flow at outlet of vent hose (hose disconnected). If weak, remove lint screen and retry. If now has brisk flow, clean screen in hot water and detergent.
Aug 01, 2009 | Dryers
Dryer doesn't dry, lint not cloged, gas ignights
When you say lint not clogged I assume you mean the removable lint trap in the dryer. If the drum gets hot (open the door a few minutes into the cycle) then most likely you have a vent problem. You will need to check if the vent is blocked solid either by lint or if the vent pipe is crushed. I would suggest going out to whereever the vent ends on the outside of the building and see if air is getting blown out with the dryer on. If no air is coming out then chances are it is blocked. If the drum is cold then gas flame is not getting hot.
May 12, 2009 | Kenmore 72062 Gas Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Bosch Nexxt 500 Plus Dryer Logo
119 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
