Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Don't know if you can help with my T1WG2 side by side: Seems like defrost water is not going into the evaporation pan. Water is on the floor aprox. Every 6-12 hours. Seems minor what can I check before calling a repair service?
  • 4,793 Answers
Clean out the drain pipe with chlorine bleach,then see .
Posted on May 13, 2010
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Msd2556ae side by side freezer seems ok refrigerator warm? think it is in defrost mode?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 29, 2011 | Maytag MZD2766GES Side by Side...
Ice side seems to be cooling fine. The normal cool side isn't cooling properly
heatman101
Dec 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Don't know if you can help with my T1WG2 SIDE BY SIDE: Seems like defrost water is not going into the evaporation pan. Water is on the floor aprox. every 6-12 hours. Seems minor, what can I check before...
first sir inside the frzr section,look fr the drain hole located on the rear side, bottom portion of the evapoator it is hole connected in the drain hose, check for dirts that maybe blocking the flow of defrosting ice during defrost cycle it takes evey 8th hours if the timer is designed to 8hrs running time and 30mins defrost time. It almost coincides with your observation of 6-12hrs. If it is blocked try to clean, removes first all accessories or trays to have a free access to the frzr wall area,then start removing or check for clog by pouring a glass or so of water, if it did not flow freely going down, the clogging is there,if in the hose,try to push the dirts using your thumbs, if it did not work,do something practically to push the dirts inside the hose outward. you can do it sir. it is very practical,just dont forget to unplug you fridge for safety reason sir.The othe way from the rear side of your unit sir there is a back cover, remove all the screws by using philip driver,there are models that you can pull out the end of the drain hose from behind.
Mar 19, 2010 | Whirlpool ED2FHEXN Side by Side...
Viking Professional Side-by-Side seems stuck in defrost mode
The defrost timer has stopped,this model has a problem with the defrost timer not working properly.Have it checked or replace it.I don`t know if there is a recall on this unit or not,but check with the dealer you purchased it from.If I can help,let me know.
Mar 27, 2009 | Viking 42 in Built In Professional...
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaking water
Mine just starting leaking also. Water gathers in bottom, then freezessolid. then additional water leaks out. I've check ice maker and door water line. confirmed by turning off water supply. Water continues to build in bottom. I think it might be the defroster. somehow the defrosting water is not draining? Check your out and let me know what you find.
Oct 28, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
