Question about Whirlpool Duet GHW9150P Front Load Washer
My control is locked. How do I unlock the controls?
My control is locked. How do I unlock the controls. Thanks
  • 283 Answers
Press and hold "End of Cycle" button in for 3 seconds
Posted on May 13, 2010
2005 Chevy Impala. The door locks keep locking during drive.
It's probably a bad input to the BCM - body control module ! Have it checked for DTC'S - diagnostic trouble codes .
The automatic door lock function can only be enabled by the body control module (BCM) if the driver door open switch and door ajar switches are in the Closed state. For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
DTC B3064 or B3069
DTC B3127
DTC B3128, B3133, or B3138
DTC B3132
DTC B3137
DTC B3272
Your best bet , take it to the chevy dealer . Unless you own a GM factory Tech 2 scan tool an have access to factory sevice repair info.
The outputs to the door lock actuators are controlled by the body control module (BCM). When the BCM receives a lock input from a door lock switch, or a keyless entry transmitter, it applies battery positive voltage to the door lock actuator lock control circuit, a ground to the door lock actuator unlock control, and the driver door lock actuator unlock control circuits. When the BCM receives an unlock input from a door lock switch, it applies battery positive voltage to the door lock actuator unlock control, the driver door lock actuator unlock control circuits, and a ground to the door lock actuator lock control circuit . When the BCM receives an single Unlock input from a keyless entry transmitter, it applies battery positive voltage to the driver door lock actuator unlock control circuit and a ground to the door lock actuator lock control circuit to unlock the driver door. A second Unlock input from the transmitter applies battery positive voltage to the door lock actuator unlock control circuit, and a ground to the door lock actuator lock control circuit to unlock the passenger doors.
This diagnostic procedure supports the following DTCs:
• DTC B3128 Left Front/Driver Door Unlock Circuit High
• DTC B3133 All Door Unlock Circuit High
• DTC B3138 All Door Lock Circuit High
Jul 21, 2017 | Cars & Trucks
Control lock preventing the operation of the stove
Hi Bruce, this is AP!
I understand you are struggling with the lock feature on your Electrolux duel fuel range, model EW30DS65GS. In order to cancel the Control Lock feature, press Control Lock and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing Control Lock and holding for 3 seconds. The Door Lock indicator light will flash for 20 seconds until the door has finished locking. Do not attempt to open the door while Door Lock is flashing, this may result in the door locking open.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.electroluxappliances.com/Owner-Support/Product-Support/
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Thanks,
Apr 02, 2014 | Electrolux EW30DS65GS Dual Fuel (Electric...
The controls locked is displayed. what causes this and how do i get the controls unlocked.
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Control Panel is locked
Is the control panel locked or just not working ??? If its actually locked push and hold for three to four seconds the (cycle signal ) volume selection button on the far right of the control panel.if the panel is locked that will unlock it... If you are still having problems we will no its not a panel lock issue.... Good Luck
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked. How to unlock?
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Control locked
Hi
Thanks for using FixYa. To unlock the controls press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series FRONT LOADER, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Upright Driver is on the lock control
TRY UNPLUGGING THE DRYER OR DISCONNECT POWER BY TURNING OFF THE BREAKER. LET IT SET FOR 5 MINUTES OR MORE. THEN, REAPPLY POWER AND SEE IF THE MICROCOMPUTER RESETS. IF NOT, LOOK AT THE CONTROL FOR A LITTLE LOCK SIGN. SOME CONTROLS HAVE A CHILD LOCK FEATURE THAT LOCKS THE CONTROL AND HOLDING THAT BUTTON FOR 5 SECONDS WILL LOCK/UNLOCK THE CONTROL. IF YOU CAN'T FIND IT, TRY STARTING AT THE LEFT SIDE AND PRESS EACH BUTTON, ONE AT A TIME, FOR 5 SECONDS TO SEE IF ONE WILL UNLOCK THE CONTROL. IF YOU FIND IT, WRITE IT DOWN FOR FUTURE REFERENCE.
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
