Question about Kenmore Elite 45986 Front Load Washer
What does the code f17 mean? I've had it happen twice according to the mannual I cancel the wash cycle and select drain and spin. Why does this happen? I have a less than a year old front loader Kenmore Elite washer/dryer.
  • 15,935 Answers
F7
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Generally if everything checks good, you'll want to replace the MCU because it's not reading the motor correctly.####
Posted on Sep 29, 2010
MHW6000XW LIST OF ERROR CODES AND WHAT THEY MEAN
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
Jul 10, 2015 | Maytag MHW6000XW - MaximaTM...
What does the F and H mean
Do you mean "HF"?
According to the manual HF means water inlet problem.
-Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer.
-Are faucets completely turned on?
-Are screens at inlet hose connection clogged?
-Are hoses kinked?
-Are inlet hoses frozen?
Plug in washer, re-select cycle and press START. If the problem remains, call for service.
Or you can post the problem at Repair Clinic. They might be able to help further, and they sell parts if you need.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 10, 2015 | Kenmore HE2 Plus Front Load Washer
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
Flashing f code
Hi, "F" Variables (F4 to F16) (Electrical Problem) Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
Oct 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Flashing F and H
I have the same problem, Code f and h flash, I press cancel once and then start and it works.... but it is frustrating cause i do this 10 times during the washing cycle. help..
Jul 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the code f17 mean? I've had it happen twice, according to the mannual, I cancel the wash cycle and select drain and spin. Why does this happen? I have a less than a year old front loader Kenmore...
F7
Mar 19, 2010 | Kenmore Elite 45986 Front Load Washer
Code F-20 what does it mean?
“F20” on display
(Water Inlet Problem—no water or insufficient water supply)
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
clogged? Are water inlet hoses kinked?
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
What does a flashing code HF mean? This is a kenmore elite HE3t washer. thanks
That is the code for a water inlet issue.  Meaning "no or insufficient water supply" according to the manual. It says to hit PAUSE/CANCEL twice to cancel cycle. Then unplug unit and check for:
Are faucets completely turned on? Are screens at the inlet hose connection to washer clogged? Are inlet hoses kinked? And last...Are inlet hoses frozen? After checking all those it says to plug back in, re-select cycle and press START. If problem still comes up call for service. I remember on another site someone had the same code coming up, all the inlet suggestions checked out OK and they had to call for service as it was something in the control panel/computer of the unit.
Hope your issue is something simple as suggested by the manual. Take care ; )
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front load washer
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
409 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
