Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
MFC-8669DN FAILURE I FOLLOWED INSTRUCTIONS. I DID NOT CONNECT USB, UNTIL INSTRUCTED. IT WILL COPY, BUT NOT PRINT FROM THE COMPUTER. OF COURSE I CHECKED ALL CABLES. I REMOVED IT AND REPLACED IT WITH MY BACKUP MFC9700 AND BACKUP WORKS FINE.
  • CHMDER Apr 15, 2008
    MFC-8660DN WAS DEFECTIVE. I RETURNED IT, AFTER I UNINSTALLED IT AND THEN REINSTALLED IT. IT WOULD FAX , PRINT FROM THE COMPUTER AND COPY, BUT WOULD NOT SCAN.
  • Ellie B May 20, 2008
    Everything worked fine, printed, copied, faxed, until I needed to scan. It only beeps and displays "Check Cable".
    I do not know much about computers and the terminology, but I did follow all instructions when installing to the T and all cables seem to be set up properly.
    Is this fixable or do I need to return it?
    Thank you
    Ellie B
  • Brother Master
  • 19,396 Answers
Did you check after installing the printer that you have the printer in 'installed printers' in 'control panel'?
Your printer may have been there, but not set as default printer.
Did you also notice a message popping up first time you connected the printer to usb saying new hardware detected?
Try to install and connect the printer on a different computer ( a laptop will be fine), intalling software first as usual.
If it works is either usb channels on original computer or a windows problem.
If Windows does not see the device when you connect usb (ensure cable is ok) to different computer, and you are sure you are doing everything ok, then it is probably usb printer socket that is faulty.
If Windows see that there is a new device detected, but it cannot install printer, even after doing disk setup procedure fine, then there is an issue either with the printer or with the drivers you are using (they may be for a different operative system for example).
An hardware problem of this kind is rather unfrequent, particularly on a new printer. Check that you are doing everything fine, that the printer is not in installed printer, even if not default one, and that you are using the right setup disk, and that this is performing the whole setup procedure.
Regards
Posted on Mar 29, 2008
  • Ginko
    Ginko Apr 15, 2008
    Then if it was defective, why did you vote inappropriate, inappropriate must be used for comments in no relation with the problem, please change rating as soon as possible.
A lot of these older units will not support scanning from anything but a real parallel port, it is the way the drivers were written. If you want to print, your best option in my opinion is to get a parallel print server. This adapter connects to the parallel port on the printer and then you connect a network cable to the adapter. Follow the configuration instructions that come with the adapter and you are good to go. Typically called a parallel print server.
Aug 14, 2014 | BROTHER INTERNATIONAL CORPORAT MFC-8890DW...
"Cannot be contacted over this network" after trouble shooting.
USB or Bluetooth? Put network settings in copier that match your inernet settings in Windows.
Nov 15, 2013 | Brother MFC-8480DN MFC8480DN...
Problem with installation
First Disconnect your printer
Reboot the computer
Start the installation from CD
Connect the printer when you see the screen to connect the printer
Once you connect the printer correctly to the USB it will proceed with the installation
Oct 07, 2009 | Brother Multi-Function Center MFC-240C...
To Install it to My Computer
Do not connect the computer and the printer until instructed to do so. You can prepare the printer by removing all of the packing and tape-installing the ink cartridges (making sure to remove the tape on the bottom)- hooking up the power supply and the printer...Now Find the installation disc that came with the printer. Put it in and run it following instructions. At the proper time turn on your printer and connect it to your computer's USB (I assume) The program will continue to progress when finished print a test page. If you need drivers for your printer they are contained in the link below. Select operating system download and install, again don't connect your printer and computer until told to do so.
Hope this helps...please leave rating, thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1119266&lc=en&cc=us&dlc=en&submit.y=7&submit.x=8&lang=en&cc=us
May 12, 2009 | Office Equipment & Supplies
Mi printer does not print
a) Load the Kodak Inkjet Printer Software CD into the
CD-ROM drive. Follow the on-screen prompts
when the instructions appear.
If instructions do not appear, click Start, then Run.
Select CD-ROM drive and type setup.exe, then
press ENTER.
b) Connect the USB cable to the printer when
instructed. Continue to follow the on-screen
prompts until installation is complete.
Do not connect the USB cable to
the printer until instructed during
software installation.
USB
To set the printer as the default:
In XP:
Start Printers and Faxes
Right-click the icon for the printer you want to use as the default printer, and
then click Set As Default Printer.
In Vista:
Start Control Panel Hardware and Sound Printers
Right-click on the printer you want to use, and then click Set As Default Printer.
Here is the setup guide:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/ESP3/1K3687-ESP3-setup_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
Have loaded hp all in one for first time and after many attempts the device set up has failed to complete screen displays.have followed instructions over and over and is installed but no program or views...
To begin with you need to turn the printer on by the electric outlet, but not the usb lead to the computer, when you turn the printer on for the first time it will print an alignment page, put this face down on the scanner bed, and then load the software, the software will tell you when to connect the usb lead. Do not connect the USB lead until instructed to do so. You will then be guided on what to do next on the screen and which parts of the software you want to run. I suggest doing a complete install as this will come with HP solutions enabling you to get help if you run into problems. If you have the software loaded on the computer but it failed to connect the printer then maybe windows tried to pick it up. Do not connect the usb lead and windows will not pick it up. Uninstall the software and try again as instructed above. When the software starts to load and it instructs you to connect the usb lead, windows may tell you that it has found new hardware, ignore the pop up as the drivers will be loaded from the cd.
I hope this helps
Nov 30, 2008 | HP Computers & Internet
Instructions
first you will have to install the cd that came with the printer. i will assume that you bought the printer new, some where while you are installing the cd it will ask you to plug the usb cable in to the printer. one end into the printer marked usb and the other end into a usb port on the back of your computer. if everything installed correctly, you will be ready to print to the printer. good luck brother tech
Sep 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Can not get my printer to print from the computer
Unfurtunately you didnt tell us what pc system you run: Is it XP, Win2k or Vista?
The latter one wont be able to connect to your pc.
For the mfc 210c are only drivers for xp and win 2k, 98se avaiable.
You need another (newer) mfc (mfc240 or 235) if you run vista.
Anyway, if you run xp, download the aggrssive usb driver remover from the brother homepage and delete the drivers installed.
After a restart of the pc do have the mfc DISconnect from usb port (which must be one of the pc: NO hub!). Insert install disc and wait until pc software demands the connection to mfc. Connect now to pc usb. Let the software finish the installation. This should work for xp and win 2k/98se.
Mar 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
