Hi everyne PLEASE HELP ME i have a problem with
Hi everyne please help me i have a problem with my copier minolta ep1085 an error comes on the display c0520 and when i switch the machine on after a few seconds is switching off what shell i do thanks very much!!!!!!!!
  • 26 Answers
SORRY. YOUR MACHINES FUSER OVERHEATED CAUSING THE 502 CODE. YOU CAN NOT RESET THIS CODE IT IS A SAFETY
LOCKOUT. A SERVICETECH CAN RESET IT CHECK THE FUSER
AND GIVE IT A CLEANUP FOR ABOUT 200.00 IF FUSER PARTS ARE NEEDED IT MAY TOTAL 400.00
Posted on May 17, 2010
I am using a machine Konica Minolta 920. its showing an error of 2350 which i could not find in the list of Machine Manual can any one please help me on this.
Have you thought that perhaps contacting the manufacturer thru their website or a phone call and asking tech support , might get you some results .
Jul 29, 2016 | Konica Minolta Office Equipment & Supplies
How can i fix Cof30 in my copier minolta ep1085
replace the developer first, if not then get a new ATDC sensor located under the developer unit.
Mar 09, 2015 | Minolta Office Equipment & Supplies
Minolta cspro ep1085 need to know if there is a hard drive in this copier
No there is no hard disk drive in the EP1085. This was an analog machine and as such had to provision for PC connectability, printing or scanning. Therefor no hard drive needed or offered.
Thank You for using Fixya!
WheatlandServices
Sep 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Hi, My konica 3340 is displaying the following message: -service please call: 18-04 with p-key handling errors Please help.
pretty sure is to do with main paper bin lift up mechanism try opening paper bins and using manual feed thru the side the try each bin in turn. hope this helps
Jul 03, 2010 | Konica Minolta Office Equipment & Supplies
Hi everyne PLEASE HELP ME i have a problem with my copier minolta ep1085 an error comes on the display c0520 and when i switch the machine on after a few seconds is switching off what shell i do THANKS...
Sir,
To fix this problem will require removal of the rear cover you will need to be careful because this will require you to reset the machine with the power on take the cover off (top cover rear) you will see a circuit card on the card is a small black button. press it remember the machine must be on be care ful. if the code comes back on the fuser (the hot part of the machine that fuses the toner to the paper) is broken lamp, thermistor, or theromsat is gone.
Mar 19, 2010 | Minolta Office Equipment & Supplies
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Oct 03, 2009 | Minolta EP1083 CS/PRO Copier
Copier only copies 90% of sheet in 100% mode
you have to go to service mode to adjust it that's ,technician's job,better looking for a local service provider
Dec 09, 2008 | Minolta EP1083 CS/PRO Copier
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
135 people viewed this question
jasbo
jasbo
