Question about Garden
How do i tighten the chain on an electric royal einhell 1840/1?
    President:
  • 2,220 Answers
A very comprehensive OM follows:
http://www.einhell-uk.co.uk/downloads/1840_Electric_Chainsaw.pdf
See page 11, The only thing I saw lacking is a caution to elevate the nose of the bar when making adjustments and tightening the side cover else it will require frequent adjustment (slack).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
It appears to be a quality product. I wish they were available here.
Posted on May 13, 2010
How to change the blade on my einhell lawnmower
turn it over and look at the blades . that might help you figure it out .
Jul 14, 2016 | Worx 17In Electric Lawnmower By
Adjusting an electric chainsaw bar and chain
UN PLUG FIRST THEN Loosen the bar and lift with the chain then tighten with a screwdriver the screw is normally found at the front beside the bar re tighten the bar the chain should not be over tight check chain oil
Jul 17, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
Tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
Nov 05, 2011 | Electric Chainsaw Sharpener
Electric 12" 1.5hp, need to
Remove fasteners from plate holding bar in place, bar and chain can be removed at this point. To tighten find tension screw, turn clockwise.
Sep 02, 2011 | Remington Electric Chain Saw
Hello James;
Your saw is listed here and contians a link to "isc-gmbh" for an instruction manual. My German is a little weak.
http://www.einhell.com/englisch/englisch.aspx?file=gartentechnik
I think this will get you to a "Contact Us" page where you can make your request.
http://www.microsofttranslator.com/BV.aspx?ref=IE8Activity&a=http%3A%2F%2Fwww.isc-gmbh.info%2Findex.php%3FPHPSESSID%3D4848211954ba3bd3d5041a%26mainid%3D4%26subid%3D8
I must admit I am not familiar with your saw and many electrics are different. This is a very good manual for an electric and while it may not be exact is good guidance. Please obtain the correct OM for your saw, but this should work in the interim.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Garden
How do you put a chain back onto a chainsaw
on one side of the saw are two nuts and a chain tightener screw. loosen the nuts but don't take them off. turn the tightening screw counter clockwise. the bar should slide backwards. the chain goes over the clutch disk and the tangs go into the bar groove. just keep pressing the tangs into the bar all the way to the tip and around the tip sprocket. now turn the adjustment screw clockwise which will tighten the chain. don't tighten it too much! leave a little "play" - tighten down the nuts. plug in the saw and start it. if the saw has a chain oiler press the oiler a few times. as you use the saw the chain will expand and loosen. loosen the nuts and tighten it again just a little.
Oct 25, 2009 | Electric Garden
User instructions for a spear and jackson 2000wat
Spear & Jackson FAQ
Question: Is there a parts stockist in my area?
Answer: Einhell UK operate a mail order system for shelved spare parts & accessories. There are currently no other Einhell spares stockists in the UK.
Aug 30, 2009 | Garden
Tightening chain
with the electric makita you should make sure the bar is sitting on that oval slide piece on the saw. they should fit together so that the bar will sit flush against the clutch plate and saw. attach the cover with the nut and tighten just enough to hold the cover on. then turn the screw on the nose of the saw, next to the bar, and then tighten the nut the rest of the way. if there's slipping or the chain wont tighten you should inspect the bar to make sure it is sitting flush against the saw.
Nov 08, 2008 | Makita 5012B 12'' Electric Chain Saw
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
