Question about Tomtom ONE 3RD EDITION GPS Receiver
Its telling to insert my sim card when its already in the unit.
Can you help?
I have seen this before on my TomTom as well.
Do you have a backup save? The was I fixed this was to plug a 1Gig SD card into a card reader (not the TomTom) and copy the backup file directly to the card and then plug in into the TomTom while turned off and then powered it on.
if you do have a backup, you should be able to find it under you My Documents folder under the TomTom folder.
Posted on Aug 13, 2008
SOURCE:
Frozen screen on a tomtom 3rd edition(1gb)
Try holding down the power button until the unit shuts off and resets.
Apr 02, 2010 | Tomtom ONE 3rd Edition GPS
My device is showing a flashing red cross with what looks like a flashing cd-what does this mean, and how do i fix it? help!!!!(tomtom one 3rd edition )
This means that the software on your gps system is corrupted and unreadable. You will need to update it/re-install the software on it. To do that, you can download this software which will automatically search for the latest updates: http://www.tomtom.com/services/service.php?id=16&tab=87
Oct 09, 2009 | Tomtom ONE 3rd Edition GPS
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Not sure what TomTom model I have.
tomtom ONE and 2nd edition are almost the same unit...one needs a SD card to make the unit work, the other unit has the SD card for optional space
in regard to the map, try: www.tomtom.com/10541
Jul 06, 2009 | Tomtom ONE GPS Receiver
Just bought yester day turns on show card goin in
The animation is telling you to insert a data card, which should have come with the device. If you have already inserted the data card (make sure there isn't a blank in the slot) then the unit is faulty and needs to be returned.
May 17, 2009 | Tomtom RIDER 2nd Edition GPS
Tomtom One 3rd Edition Map downloads
Some versions of the TomTom ONE 3rd Edition have limited internal memory(no memory card slot).
connect your device to TomTom Home to check how much memory you have available and check the map is not too big for the internal memory
Mar 24, 2009 | Tomtom ONE 3rd Edition GPS
No Sound on my Tomtom one 3rd edition GPS
I did a hard reset (hit the reset button on the bottom with the power on) and the sound was restored when I powered it up. No settings or favorites were lost.
Aug 17, 2008 | Tomtom ONE 3rd Edition GPS
My Tom Tom one 3rd edition wont stay turned on
I had this same problem and I did a reset on the device and then downloaded the newest version of the device software from TomTom. This brought the unit back. I still needed to download maps because mine came up with just Guam maps.
Hope this helps.
Jun 29, 2008 | Tomtom ONE 3rd Edition GPS
Max. Mem. Card
I think you will find that the tomtom one 3rd edition is a sealed unit.
No SD slot.
But it does have 1GB of RAM for storage and 32MB RAM for system use.
Pretty much the same internal architecture as an early handheld PC.
All updates are done through USB.
Hope this information is useful.
Feb 26, 2008 | Tomtom ONE GPS Receiver
Tomtom One 3rd edition - no SD slot and not enough memory
You could probably just manually delete the Canada/USA maps from the device, and copy over the europe (or whichever ones you need) to the device.
Just plug it in, and view the memory like a normal usb drive..delete the old, copy over the new.
Don't forget to use tomtom home to backup your gps device to your computer first (thus saving your canada maps for later..)
Afterwards, you would probably have to go into your preferences and choose the europe maps.
Jan 11, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE 3RD EDITION GPS Receiver Logo
124 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
