Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Scanning to file
I recently purchased a new desktop. I have a Brother all in one printer/fax/scanner. The printer works fine on the new computer, but when I try to scan something to file, it goes through all the steps, but then seems to get stuck on "connecting to PC" and nothing further happens. Can you please tell me how I can scan a document/picture to file to use in various projects? Thank you.
  • TheBison69 May 08, 2008
    Can't scan with unit. It says its trying to connect to the computer.......then nothing happens? I've followed the steps through the system tools/administrator options system setting etc., which was supposed to fix it but it diden't change a thing.
    Please help.
  • Anonymous Jan 29, 2009
    trying to scan to the computer dest top and it say connecting to computer
    it go through a short cycle but nothing happen
  • 832 Answers
Do run a update for controlcenter and have a look at the faq, too
Posted on Mar 30, 2008
Brother mfc-j6510dw will not scan
This may help others with scanning issues:
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
New computer is Windows 7 - 64 bit Printer is Brother MFC-8820D. Printer works fine - computer does not recognize the scanner feature of the MFC. Have tried both USB and LPT1 connection to the new...
I lost my network fax and scanning when I upgraded to Win 7 as Brother had no support for Win7 and this printer. Very disappointing.
However, I recently downloaded the MFC-8370DN install package from the Brother website and installed it on my Win7 64 bit Asus laptop. The installer couldn't find my MFC8820DN, but I manually entered the IP address ( in my case). The install completed cleanly, after a reboot I can now start Brother Control Centre 3 and scan and fax from my 8820DN over the network. All good, no need to buy a new printer just yet...
Apr 26, 2011 | Brother MFC 8820D All-In-One Laser Printer
I can't find software for Brother MFC-6800 printer for Vista....I can print only..I can't find scan, copy software for vista
The OS has a built-in driver that should automatically install when the USB cable is connected. Check Windows Update for new and optional updates if you don't see the printer appear. If you use a bi-directional parallel cable (with the computer properly set up), use the Printer Wizard and then the Add Device Wizard (IIRC). The scanner won't work over the network.
Try using one of the programs built into Windows: Windows Fax and Scan (New Scan), Paint (File > Import from Camera or Scanner > New Scan) or Photo Gallery to launch a scan. Alternatively, get a third-party software option (Paperport, for example).
Go here: to get a utility to improve the scan resolution.
I hope this helps.
(Scanner problems can often be resolved with a new data cable and a direct connection between the unit and the computer. This assumes that the scanner is unlocked (for those with a transport lock) and that the unit is properly lighting up and the scanner is moving freely.)
Nov 22, 2010 | Brother MFC 6800 All-In-One Laser Printer
I bought a new hp computer with Windows 7 OS. My hp Officejet 7310 now will not scan. The HP Solution Center that was downloaded with the HP Officejet All-in-One series Windows 7 driver disc (new, just...
A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product. With the basic driver, some of the advanced product features are not available. You can print from a software program, and import and view images on a memory card, if your product has a memory card slot. With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. How to Scan a Document in Windows 7 By Greg Harvey The Windows Fax and Scan utility enables you to scan documents and pictures. Before you can scan documents and pictures, you must have a scanner installed on your computer. Your scanner must be listed in the Devices section of the Devices and Printers Control Panel window.
To check to see if your scanner is properly installed, open the Device Stage. Choose Start?Devices and Printers. If Windows doesn't automatically find your scanner, you can manually add it in the Devices and Printers window by clicking the Add a Device button in the toolbar and following the wizard's commands.
  1. Choose Start?All Programs?Windows Fax and Scan.
    Windows 7 opens the Windows Fax and Scan window.
  2. Click the Scan button in the Navigation pane, then click the New Scan button on the toolbar.
    The New Scan dialog box for your scanner opens.
  3. Use the settings on the right to describe your scan.
    By letting the computer know what you're scanning, its color profile, and the type of file you plan to create, you enable Windows Fax and Scan to create the highest quality scan.
  4. Click the Preview button to see what your document will look like.
    Make any last minute changes.
  5. If you're happy with the preview, click the Scan button.
    Windows scans the document and presents you with an image of your document.
  6. Click the Save As button and complete the necessary information.
    Enter the filename, the type of graphics file you want saved, and then click the Save button.
To automatically forward the document you've just scanned as an attachment to a new fax message, click the Forward as Fax button.
The scan feature in the Windows Fax and Scan utility is set primarily to scan text documents. If you want to scan a photograph or other graphic, you're better off doing that directly within the Windows Live Photo Gallery.
Read more:
Nov 15, 2010 | Computers & Internet
Got a Brother MFC210C
The scan to email function works with applications like outlook. If your email is web based like hotmail, you will need to scan to file and attach the files to your email.
Feb 25, 2010 | Laser Brother® MFC7225n Network-Ready...
Wont scan to computer
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Dec 02, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC Networking Problem with New Router
When you purchase a new router you must change your security settings to accept that program so it can be ran to work with your os please check your firewall settings to see if they are blocking any new router installs you can do this by selecting start-programs then go to security settings and check your network connections and settings for your security settings.
Oct 05, 2009 | Brother MFC-7820N Printer
Same problem. Only when i am scanning or faxing it does this.
The left side hinge may be broken, or the sensor flag where you insert documents can be broken or jammed.
Aug 03, 2009 | Brother MFC-8860DN Printer
How to connect the scanner into the computer
Are you trying to start a scan with a button on the printer / scanner?
With your pc on and the printer / scanner on, click on "my computer" if theres not an icon on your desktop you will have to click on "Start which is on the bottom left of the screen, then on either my computer or computer" You will see a list of drives but scroll down to see if there is an imaging device connected.
If you double click on the imaging device it will open up microsoft scanner and camera wizard, follow the instructions and it will scan..
I hope that helps..
May 13, 2009 | Brother MFC 210C All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
