Question about Danby DCD5505W Electric Dryer
How do you take apart a Danby Designer dryer to replace the belt?
  • 20 Answers
INSTRUCTIONS TO CHANGE DRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF THE FRONT THAT GO FROM BOTTOM UP
REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT REMOVE THE FRONT SCREW FROM THE CENTER BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP
REMOVE THE 2 SCREWS ON EACH SIDE AT THE TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT REMOVE THE 2 SCREWS ON EACH SIDE OF THE INNER BULKHEAD PANEL AND REMOVE THE PANEL AT THIS POINT YOU CAN REPLACE THE BELT,
IDLER, AND MOTOR MOUNTS THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Posted on May 23, 2010
Danby DDW1805W dishwasher won't drain
I had this problem and I had to take the shared drain pipe apart. I found a huge cement-like plug of coffee grounds mixed with flour from bread-making. I removed it all and now the machine drains freely.
Jun 13, 2014 | Danby DDW1805W Designer Series...
Here are the Danby instructions: First Make Sure that Dryer is Unplugged from outlet.
THE FRONT THAT GO FROM BOTTOM UP. REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREW FROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACH SIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVE THE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THE BELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Mar 19, 2010 | Danby DCD5505W Electric Dryer
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
Oct 31, 2009 | Danby DCD5505W Electric Dryer
How replace belt danby electric dryer dcd5505w
Remove the retaining screws off from the front panel. Remove the two wires connected to the door switch(the wires can go back on either way).Pull the front panel away from the drum. Look down to the bottom right corner facing the front of the unit and locate the tensioner and drive pulleys. If the old belt is still intact(which is usually not the case) remember the routing order of the belt. Slide the new belt onto the drum keeping in mind which side goes to the drum. The ribbed side should face outward.Next you want to curl the belt over the tensioner(providing the tensioner is still in it's slot) and then over the drive pulley. Replace the front panel and the door switch wires. You're good to go. Thank you, Dana
Oct 06, 2009 | Danby DCD5505W Electric Dryer
My danby dryer is not heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
stuu
Oct 03, 2009 | Danby DDW1805W Designer Series...
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Where can I buy the dryer belt?
I bought my dryer belt dirrectly from Danby. They first gave me the name of a company to get it from, when I called them, I was told they no longer handled Danby. So I called Danby back, the woman I talked with was very helpful. She ordered the belt and sent instructions on how to change the belt out myself, and said if I had any problems with the installation, give them a call. It took me about two and a half hourse to replace the belt. But if I had to do it again I think I could do it in 30 to 45 min. By the way I'm a 60yr old woman.
Sep 29, 2008 | Danby DCD5505W Electric Dryer
Replacing bryer belt
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Jul 03, 2008 | Danby DCD5505W Electric Dryer
Part Number DB-6060532 available at marcone.com
Mar 18, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
211 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
