Question about Dell Dimension 4600 PC Desktop
It won't start it is black - Dell Dimension 4600 PC Desktop
  • 721 Answers
Well that narrows it down to about 30000 things. Since that is all you know, I can't go into real deep tech stuff,so here's the basics:
Make sure it's plugged in & that if plugged into a power strip that it also is on & suppling power.
Make sure the monitor is plugged in to power & that it is connected firmly to the proper video port on back. If it uses a video card, that's where it plugs in,otherwise it goes to the onboard port.
If none of the above applies, then listen for any noise, a beep or series of them,lights if any,fans,etc. If none are present,you got big problems. Dell & bad motherboards are very common on dimentions in general.
Posted on May 15, 2010
2006 sts won,t crank, lights up,go to start black screen,can jump stater at relay
go to start black screen ??? Need more info from you . What screen goes black . What light's up ? The instrument panel ? Do the headlamps light ? Do they go dim or out when trying to start the vehicle ? Is the battery good an have good cable connections .
Mar 21, 2018 | 2006 Cadillac STS
I over heated,the serpentine belt snapped. Opened the hood to find steam rapidly coming out of both the antifreeze and out of the engine right by the head gasket. It wasn't smoke not blue or black jus
Perform a compression test on your cylinders. One unfortunate result of overheating is the blown head gasket. Without compression your motor will not run. Tester are not super expensive or some stores will lend tools.
Jul 09, 2013 | Cars & Trucks
Black decker 36v won't start
Sounds like its burnt out. Or shorting out.
Jul 04, 2012 | Black & Decker 19" Electric Lawnhog...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
My emachiens pc won't boot up, it will turn on but
hi. firstly troubleshooting your ram and hard disk.
Dec 30, 2011 | Computers & Internet
The machine won't start although the light is on.
Black and Decker machines go through a slow warmup before they start kneading. That is normal. It takes a few minutes. If your machine hasn't started kneading within 30 mins. then you DO have a problem with it.
Aug 28, 2011 | Black & Decker Kitchen Appliances - Others
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 2000 Chevy Impala won't turn over
1st, make sure that your car's battery is in good condition, if so, then check the battery cables out to make sure they are tight, and not corroded. if they are corroded with acid, you can clean them with a solution of water and baking soda, then rinse the cables off , and dry them off. you mentioned that your car won't turn over, do you mean not starting, or just won't try to start, either way, you can check out the start relay, located under the hood in a black box, on the drivers side.
May 10, 2011 | 2000 Chevrolet Impala
Dell Dimension 4600 PC Desktop Logo
82 people viewed this question
Alun Cox
