Whirlpool duet sport washer and dryer
The washer recently started making a strange grinding noise when it goes into cycles. i wash big bathmats that my puppy uses for piddle pads quite frequently, however, the washer is supposed to be able to handle big loads, so i don't know what's causing it.
the dryer started acting strange a few weeks ago. the dryer light would flicker and then finally come on when opening the door. it finally stopped altogether, including the power. it acted like the cord might be falling out, causing it to have this intermittent problem, but then we checked the cord, saw that it's fully plugged in...still no power. any advice?
very, very frustrated. we have owned these for less than a year.
SOURCE:
  • 36 Answers
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
take off the bottom kick panel locate the drain pump now there will still be water in the washer so take caution when following this procedure i use a shop vac and suck all the water out of the drain hose to prevent a mess then the frount of the drain pump will screw off check it for blockage or damaged impeller blades
Posted on Dec 28, 2007
ginko
  • 19396 Answers
SOURCE: Whirlpool AWM 6100/s Front load washer
That is either a faulty timer control, or more probably a faulty door latch.
I think you need to replace the door latch.
Posted on Nov 01, 2008
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 107 Answers
SOURCE: Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Posted on Jan 20, 2010
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
MY washer starts grinding when it starts a cycle
OK, are you certain that the shipping bolts were removed when the washer was delivered and installed? I've had folks that complained after 3-4 years that they're front loading washer was now making all sorts of strange noises when their kids came home from college and really stuffed the washer with clothes, etc.
Check the installation and owners manual for the diagram that shows the shipping bolts that should have been removed from the rear of the washer when it was installed in your home. There are usually 2-4 of these, depending on the brand/model of washer.
If the shipping bolts have been removed (all of them!) then you can pull the washer out from the wall and see if there is something that might be hitting the drive belt/motor underneath the washer. It's possible that a tub suspension spring(s) and/or pulley(s) may have come off their mount causing the noise.
Another thing to look at is to see if the pulley on the motor shaft has come loose and might be causing the noise, as it might have worked loose but still catches on the keyway in the shaft enough to still function.
I usually pull the unit away from the wall with the hoses hooked up so I can remove the rear cover and watch everything while I run the unit through a short wash cycle. That is a quick and easy way to see what might be causing the noise. From there, you can start to focus in on different areas to verify or eliminate them as the noise source. Of course, it goes without saying, be very careful not to get your hands caught while the machine is running and unplug it before you reach in and start feeling around the unit.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Oct 11, 2008 | Whirlpool Washing Machines
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
