Dimplex DAC15006R exhaust segment won't turn off
My Dimplex DAC15006R has acquired an unusual issue where turning it off does not disengage the exhaust segment though it turns off the blower part. Any suggestions would be most welcome (apart from the obvious get it serviced as I'm reasonably competent with repairs if given instruction!).
    President:
  • 1,515 Answers
Hi, correct me if I am wrong, but are you saying that the small inducer exhaust fan motor runs and has power to it all of the time? If this is the case, the sequence of operation on this unit when starting up is that this inducer fan motor comes on first to purge all gases from flue and to pressurize the combustion chamber through out the heating cycle.But, when the heater calls to shut off, so will this motor. This inducer motor gets its power from either a circuit board on this unit or a electronic control module that supplies voltage to it.Which ever you have that supplies power to this motor you will have to follow the 2 wires back to where they terminate will be the defective part. Either the main circuit board or ignitor module is the faulty part. If you can, follow the leads from the motor back, and get back to me and tell me where they terminate and if there are any controls in between them and where they connect. Thank you and,
Sincerely,
Shastalaker7
Posted on May 13, 2010
  • Robert Horton
    Robert Horton May 17, 2010
    Hi, I am just doing a follow up on your problem. Please let me know if I was any help so you can grade me and I can close this out.
    Thank you, Sincerely,
    Shastalaker7
Fire wont mist ad keeps turning its self off 3rd time lucky at posting this as not a car or truck and it keeps coming up under cars or trucks
You can call Dimplex directly for Tech Support:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex Compact Electric Flame Stove...
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Trunk won't open
The actuator may sound as though it is working but the latch could be damaged or misaligned. Also, the actuator could be too weak to operate the latch. If it is necessary to replace the actuator, your Camry is old enough to make a junkyard a likely source.
The light has gone out on my dimplex ASP20 fire.
There are several light bulbs that create the flame effect. However, it's unusual for all to go bad at one time. If you still have your Owners Manual, it will tell and show you how to access and change the bulbs. In the meantime, turn the Master ON/OFF switch to OFF and Unplug the unit from the wall outlet. Wait 12 to 15 minutes and plug the unit back in. Turn ON the Master ON/OFF switch and test each function one at a time. Hopefully, the time unplugged gave the unit time enough to reset itself. However, if this continues to occur on a regular basis, contact Dimplex USA, Technical Service at
888-346-7539
If you want to Troubleshoot and access the bulbs yourself: Remove the Plexiglas from the front of the fireplace and carefully remove the logs. The ember bed below where the logs were sitting will lift out and you'll have complete access to the bulbs. The bulbs are 60 watt, small base, chandlier bulbs.
Hope this helps you solve the problem
Mar 21, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a Dimplex free standing electric "fireplace" and the "flame" no longer shows. I don't know how to take the back off to see if it is bulb related. the serial number is 32502A10...
There is no need to remove the entire back panel, unless you want too. It's held on with about 6 sheet metal screws. There is another smaller access panel near the bottom of the back panel that is removed to access the light bulbs. It is a bit unusual for all the batteries to go at one time. I suspect it's a circuit that has locked out. Here's what you can try, to get the unit to reset itself. Turn the Master On/Off Switch to OFF. Unplug the heater for 12 to 15 minutes before plugging it back in. Once plugged back in, turn the Master On/Off Switch to ON. Try operating all the functions of the stove one at a time. If the flame effect returns to normal, then the problem is solved. If it continues to reoccur unplug the unit and call Dimplex USA, Technical Service at 888-346-7539. If necessary for you to call, you will need to have the Model Number of the unit, as well as the Serial Number.
Hope this helps you solve the problem.
Mar 20, 2011 | Dimplex Compact Electric Flame Stove...
I have a Dimplex Small Electralog Stove Fireplace CS1205, it's two years old but barely used until this winter. A couple months ago, the flame stopped working and now the heat keeps turning off after 5...
More than likely, the interior of the unit needs to be cleaned. When it's in operation, it sucks dust and link into the fan and heater elements. When it's not, spiders love to go into and build nests. If badly clogged, it can cause the heating element to over heat and shut off. Carefully, removing the back panel of the stove will give you access to just about everything. As far as the flame is concerned, the bulbs may need replacing. Although, it's unusual for all of them to go bad at one time. You or your nephew can replace them after the unit is cleaned. A vacuum that has a hose, brush attachment and crevice tool, will work well in the cleaning of the interior. Be sure to turn the Master ON/Off Switch to OFF & Unplug the unit, before attempting and maintenance on it.
If after performing all of the above, the unit still doesn't work properly, contact Dimplex USA, Technical Service 888-346-7539, for further advice.
Hope this helps to solve your problem. Please let me know.
Mar 17, 2011 | Dimplex Compact Electric Flame Stove...
HI THE 3 INDICATER LIGHTS WERE ALL ON SHOWING THAT THE HEAT SHOULD HAVE BEEN ON FULL CAPASITY!!BUT THERE WAS NO HEAT BLOWING OUT OF THE GRILL!!
Not an unusual problem with any electric fireplace heater. I suspect the overheat circuit has shut the heating element down. Or the element has burned up (that's not unusual either).
In any event, turn the fireplace OFF and unplug it. Wait 30 minutes before plugging it back in. During that time, the overheat circuit may reset itself. If that fails to solve the problem call The Technical Service Dept of Dimplex USA at 888-346-7539, Monday - Friday, 8:00 a.m. - 4:30 p.m. EST. If it ends up needing parts, you can order them at that time.
Have the Model # and Serial # of the fireplace, handy. As you will need to provide that information to them, as well as the date of purchase.
Mar 02, 2011 | Dimplex DF3003 Electric MidSize Heater
My Dimplex model #6901470100 (purchased new in 2007) just stopped working. It was on then just turned off by itself. Both lightbulbs are OK. What would cause this?
It probably overheated and the overheat module shut the heater down. It may reset itself once it cools down. Or the heating element has burned out. There are a host of issues with these electric fireplaces (not just Dimplex). They are sold as a decorative, supplemental heat source, but in fact, if you get more than a years use out of it without a problem, you're probably the exception. The heaters just aren't meant to run for a long period of time. It's like turning on a blow drier and letting it run for an hour. Nine times out of ten the blower driver will overheat and burn out.
I really wish I had better news for you (I answer this type of question at least 5 to 6 times a week), but I don't.
The only good news would be, if it's still under warranty (one year), have your Proof of Purchase and contact Dimplex USA. Technical Service: 1- 888-346-7539. Customer Service: 800-668-6663
Feb 23, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
