Question about Kodak Open Box i50 Flatbed Scanner
Selected scanner was not found adobe acrobat
Hello, I hope someone can help me.
I have been using Adobe Acrobat 6.0 standard for years. Been scanning documents (hundreds if not thousands) for my home business. Now all of sudden I can't scan. For the past week keep getting this error message:
Error while interacting with scanner. the selected scanner was not found.
The selected scanner is a Lexmark all in one X1150. Only scanner I've used since I put AA 6.0 on my computer.
I can scan the opposite way (through the lexmark to a PDF file), but first I have to preview it (to size it), then I have to scan it, and then save it as an individual file, then combine them together. Rather time consuming when working with a 60+ page document.
Any thoughts at all will be greatly appreciated. Thanks, eh.
Mike
  • TES8956 Apr 29, 2008
    Same problem, now receiving a message "selected scanner not found" that scanner being a HP PSC 2210 all-in-one. New problem, has worked prior to present time.
  • 39 Answers
First downloaded the trial version of Acrobat 7.0 and removed
Acrobat 6.0. Test scanning ok it will worked!
Proceed to uninstall the Acrobat 7 trial version and
reinstall the 6.0 version you own, try this i hope it will work for you.
All d best
Posted on Sep 07, 2009
SOURCE:
I need a serial number for adobe acrobat 9 standard
Locating Your Serial Number in Adobe Acrobat 1 Open Adobe Acrobat on your computer. 2 Select the "Help" drop down menu. 3 Select "About Acrobat" from the drop down menu. 4 Look in the lower right hand corner of the graphical dialog box for a 20 digit number separated by dashes every four digits. This number is your Adobe Acrobat serial number. Read more: How to Find the Serial Number for Adobe Acrobat on My Computer ' eHow.com http://www.ehow.com/how_5793106_serial-number-adobe-acrobat-computer.html#ixzz2HuL3UYak
Jan 14, 2013 | Adobe Acrobat® 8.0 Standard Full Version...
My adobe acrobat reader was working yesterday but today it said the adobe acrobat reader that is running can not be used to veiw pdf files adobe acrobat reader 8 or 9 is required but that is what i have on...
Ensure that you only have one version of Adobe Acrobat installed. I've found that often enough, if Reader and the full version of Acrobat are installed at the same time, it can cause problems like these.
If that is the case, try uninstalling Reader, so that only Acrobat Standard remains.
May 05, 2011 | Adobe Computers & Internet
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
How can I: Enable document rights using Adobe 9...
When you select Advanced > Enable Usage Rights in Adobe Reader the Enable Usage Rights in Adobe Reader dialog box shown in Figure opens
Click Save Now and your file is enabled with the four items described above. You need Acrobat Professional for all enabling features. These commands are not available to Acrobat Standard users (Acrobat Standard available for Windows only in Acrobat 8). When you select the Enable Usage Rights for Adobe Reader menu command and click Save Now all enabling features are added to the PDF.
pleas say thank's
Apr 01, 2010 | Computers & Internet
I can't figure out how to scan multiple pages to one file
Hi There !!
Thank you for choosing fixya.com
It is possible to scan different batches scanned from the ADF into one PDF file. When loading more pages in the ADF after the first realm is finished, it asks if you want to continue scanning to the same file. After that, it will continue scanning to the same file. However, this feature can be selected in the Adobe Acrobat application itself. From HP software, if we load the paper after one realm of paper in the ADF is finished, it will scan the second realm to a different file. If you want to continue scanning to the same file, you need to have either Acrobat Exchange or Adobe Acrobat installed on the computer. Adobe Reader will not provide this feature. After installing either Adobe Acrobat or Acrobat Exchange, perform the following steps to scan pages to a single file:
  1. Make sure your scanner is turned on.
  2. Start Acrobat Exchange or Adobe Acrobat.
  3. Put the document into the scanner (usually face down on the scan bed).
  4. In Adobe Acrobat, click File , then Import , and Scan .
  5. Select the device and whether you are scanning a single- or double-sided document.
  6. The scanning software opens and the scanner completes a preview scan.
  7. When the preview scan comes up, make any adjustments you would like, including selecting the area you want to appear in the final scan.
  8. Click Scan . This will get the final scan into the computer.
  9. Your scanning software should take you back to Adobe Acrobat.
  10. In Adobe Acrobat, you should see a small window asking you if you want to scan another page. If the document you are scanning has more than one page, click the Next Page button. If this is the only page, click Done .
    NOTE: Scanning multiple pages causes each page to append to the previously scanned page. If you have multiple pages, but want them to be in different files, click Done after each page to create separate files.
  11. When you have scanned the last page, click Done on the window described in step 10.
  12. Your scanned pages will open in Adobe Acrobat. Scroll through to make sure that everything is there.
  13. Click File , and then Save As to name your file and save it.
Still unable to figure out, How to do this? Here are some tutorial on HP website that might help.
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1161389&prodTypeId=18972&supportTaskId=23095
Hope this would help.
Regard's
Anurag Shukla
Sep 04, 2009 | HP LaserJet 3055 All-In-One Printer
Missing Resource File
Solution: Remove Adobe Reader 7.0 and reinstall it.
Remove Adobe Reader 7.0, reinstall it into the Program Files/Adobe/Acrobat 6.0 folder, then try again to create a PDF document with Acrobat Elements 6.0.
1. Remove Adobe Reader 7.0 using Add or Remove Programs, and then restart.
2. Install Adobe Reader 7.0: At the Destination Folder panel, click Change Destination Folder and select Program Files/Adobe/Acrobat 6.0. Click OK, then Next to continue the install.
Background information
Acrobat Elements 6.0 is designed to work with Acrobat Reader 6.0. In order for Adobe Reader 7.0 to work with Acrobat Elements 6.0, install both applications in the same directory. Install Acrobat Elements 6.0 first, so you can install Adobe Reader 7.0 and select Program Files/Adobe/Acrobat 6.0 folder as the destination folder.
plz follow this link for further help
Mar 15, 2009 | Adobe Acrobat 6.0 Professional for PC
Can i use Adobe Acrobat 6.0 Standard with Vista?
Hello martin,
you can use Acrobat reader 8.0 in vista. here is the download link.
DOWNLOAD
Mar 11, 2009 | Adobe Acrobat 6.0 for PC
System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Dec 18, 2008 | Sharp AR-M205 Copier
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Kodak Open Box i50 Flatbed Scanner Logo
4,070 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
