Want to hook up a ps2 to a xdvd700 and dont know if it is possible
    Sergeant:
    Champion:
  • 250 Answers
All you need to do is go to radio shack and buy yourself a 12 volt or above momentary push button/switch (about $3) If the button swith/button comes with wires then just connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. make sure you wrap up the wires to prevent shorts.
Also make sure that the switch that you buy can be mounted because you will need to use it every time you want to use the dvdwant to hook up a - 1.gif.( you might need to drill a small hole for the switch depending on what you buy)Make sure you have enough wire so you can mount it where you can easily use it like under your steering wheel.
When you are ready to use the dvd put the dvd in the player and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the switch/button for one second and release it. The screen takes about 6 second to display the video1.gif. If it does not work then try again but this time try to push the button/switch twice. In my truck I only have to do it once and it works fine but you get the idea.
Posted on Mar 29, 2008
SOURCE:
How to test the xdvd700 before I install in the car. what wires go to possitive and what to negative
Hello there,
Well the wiring colors appear to be standard for most every piece of mobile A/V equipment out there.
Yellow = Battery Power(12V Positive)
Black = Ground / Battery Negative
Red = Vehicle On / 12V+ (or also hook it to the 12V Positive for "always on")
Here's the manual with the wiring diagram on Page 6(page 7 of the PDF):
http://www.dualav.com/support/manuals/xdvd700.pdf
I hope that helps
Mar 31, 2010 | Dual Electronics XDVD700 Car DVD Player
Sixaxis on ps2 ???
No, it's not possible to hook up sixaxis to PS2. Sixaxis is a part of DualShock 3 for PS3 which is an optional feature in the PS3 games. Playstation 2 controllers run off of DualShock 2. So sorry, but you're gonna need a PS3 for that.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
Can u hook ps2 to dual xdvd700
No you can not hook up a ps2 to the dual. It hads audio inputs but no video inputs
Oct 09, 2008 | Jensen VM9510 Car DVD Player
Dual xdvd700
dual sells them from their website for about $30
Jul 24, 2008 | Dual XDVD270 Car DVD Player
Dual xdvd700
duals websit sells them for about $30
Jun 15, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
PLEASE HELP ME WITH MY XDVD700 DOESNT PLAY DVD
i had the same problem with mine i just kept hitting the reset untill it stopped.
Feb 11, 2008 | Dual XDVD8181 Car Video Player
Need help on hooking up a xdvd700 dual without ebrake
i have the xdvd700 dual. my screen goes blank when it comes all the way up. is there a solution for that? or is that manufacture's problem?
Jan 30, 2008 | Car Audio & Video
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Ekse
