My Samsung ER-4915 cash register is frozen, with the these showing on the display "PP 0.00". Can you help me unfreeze this machine? I already have an owners manual, but it does not address this problem.
  • 12 more comments
  • smid Mar 29, 2008
    smilemaker,
    I said my owners manual did not tell me how to reset the system, could you tell me how? That is my problem, the person I usually use to help with these things does not work on Saturdays and my store is open today and only going to get busier as the day goes on, it is a liquor store. Help me get going!
    smid.
  • smid Mar 29, 2008
    I still have not heard back from smilemaker, who told me to look at my owners manual. I do have one but it does not address the problem on how to reset or reboot my cash register. Please some one help?
    smid
  • smid Mar 29, 2008
    I did as you suggested, but I switched the key to the Program settings as my machine does not have a Service Mode setting. I then followed your instructions, but it is still locked up.
    smid
  • smid Mar 29, 2008
    I do not have a C button nor a control setting for the key to turn to.
    smid
  • smid Mar 29, 2008
    pauldonp,
    First of all yes it is a Samsung ER-4915 cash register. Your ideas are making more sense now, because I have had to do this before, and have always had to hold down some keys and unplug and replug in the cash register for it to reset. My problem is I was walked through the steps so fast I do not remember them and they are not in the manual. I tried the above steps, but it is still in the same position. any othe ideas?
    smid
  • smid Mar 29, 2008
    I have no off/on switch, the key can be turned to the off position, void, regular, x,z, or p for program position. When I have the switch in p I simply unplug from the electrical out let. My key pad is raised.
    smid
  • smid Mar 29, 2008
    Message comes right away, but does make a small little noise like machine is trying to reset. The message is pp 0.00 right away. the key pad is locked up nothing works.
    smid
  • smid Mar 29, 2008
    I put my ear close to machine and checked with key in every position, no sound. That little noise on seems to happen when the electricity is turned off and on.
    Keep trying, but I know this is hard, this manual is difficult to read, but it does not have any thing about trouble shooting in it, only programing.
    Thanks for you help
    smid
  • smid Mar 29, 2008
    just wanted to let you know my manual does not tell me how to reset.
  • smid Mar 29, 2008
    We are very close. Yea! Yea! I did find a paper jam, I never thought of that. I cleared it out and did the steps above. The machine came back on and moved the paper forward on the rolls. I waited for a beep then turned key to regular, now the display says CLOSEd. All caps execpt the last letter.
    Where do we go from here?
    smid
  • smid Mar 29, 2008
    I did as you asked removed ribbon with Key in P position, then unplugged registar and turned it back on. The machine moved where the ribbon is, X,Z, and P all say 0.00 on display, but Void and Regular say CLOSEd.
    smid
  • smid Mar 29, 2008
    Yes the number keys work, but when i hit one of the other keys the machine buzzes just like it does in normal operation when we have not hit the right key.
  • smid Mar 29, 2008
    pauldonp,
    Thanks!! It looks like all systems are working now, the abc or d key I had never even used before. You solved my problem.
    Thanks for all your hard work.
    smd
  • smid Mar 29, 2008
    Every thing is working great.
    Thanks.
    smid
  • 4,102 Answers
Switch the key to the Service Mode - hold down the 00 key and unplug and replug in the machine while continuing to hold it down. this will reset the RAM
that should reset it for you ok let me know how you get on ok
Posted on Mar 29, 2008
  • 20 more comments
  • paul proctor Mar 29, 2008
    ok ill have another look again for you ill get back to you in few minutes ok
    are you sure its samsung er 4915 please check as the way to reset is listed as the way i first told you but ill have a look again and see if their is a different way.
    Also what other options on your key are their
    Turn the key to P
    Turn the cash register off
    Turn it back on whilst holding down the SUBTOTAL key
    Turn the key back to R and give it a test.
    Please let me know if you get sorted or if it doesn't fix the problem.
    Here can you try this way for me then get back to me ok
    Do you have a p setting on the key not c
    Turn key to P
    Turn cash register off
    Turn back on whilst holding SUBTOTAL key down keep pressed down untill till comes on this should now have reset the till.
    Let me know if this works it should do but let me know ok
    After trying my last comment with the SUBTOTAL key what happens when you switch back on?
    Is their an on/off switch on the till or did you just switch it off at plug then back on.
    If your is the one with an on/off switch on it try it using this if not let me know ok.
    Is yours the one with the raised keypad or is it flat?
    Sorry forgot to mention this do you know when you switch it off at mains then back on does the message come up strait away or does it take some time to come on.
    Also check for me if the display shows anything else before the error message you get let me know ok
    Also when it comes on does any of the keys change the display or is it like the keypad is not working?
    the message pp 0.00 is that correct its not php o.oo let me know thanks
    Ok thanks so what happens when key is at p then switch off then back on holding SUBTOTAL down till the till comes on do you get the message strait away or does it take a while?
    Also do any of the keys work on the till or is it like they are not working?
    Hi you know the key does turning it to another place like x z p or other settings does this change the display message at all?
    Can i also double check you turned it on and off with the key in p position and holding down SUBTOTAL till the till comes back on
    ok thanks for info read through the message before this one just to double check everything for me as its difficult from my end cus its not in front of me so im going on what you tell me so i just make sure that i got everything right, it just narrows the possible cause down for me ok.
    I will help you the best i can but i just need to rule certain problems it could be out so it might take a while to figure it out but ill do the best i can for you ok.
    Also do any of the other experts who replied to this problem have any ideas of their own that could help me narrow the problem down a bit.
    The problem my end is im going on something that i worked on ages ago so im looking things up to refresh my memory ok so try not to get wound up when i keep asking similar questions.
    Its like you telling me how to repair something from your end its not easy i guess you can understand that though ok
    just give me few minutes then ill get back to you ok
    Can you check for me if it has a constant buzzing sound its only quiet so you might need to put your head close to the till to listen let me know ok
    Thanks for the info no buzzing sound tells us their no problem with the circuitry or the receipt side of things.
    As for the manual you are right it dont give any help at all for this error your having.
    Does the manual tell you how to reset or not as i dont have the full document i just wanted to check the correct procedure for reseting as i got the 2 different ways witch you have tried both.
    If it does tell you then let me know
    ill get back to you in few minutes and see what i can find out for you ok
    just letting you know im still here so you dont think ive give up on you ok just bare with me for few minutes ok
    PP indicates a paper jam or Ribbon-foul up! First, you need to clear the cause, then you need to do a reinitialization;
    Turn
    the ECR off, turn the Key stamped with a "P" to the "P" (program) pos'n
    (clockwise to the 5 O'clock pos'n), hold down the "sub-total" key, plug
    the machine in and continue to depress the "sub-total" key until the
    printer-unit finishes cycling and the ECR "beeps!" Immediately turn the
    key (counter-clockwise) back to the "REG" pos'n.
    hi i know you all ready tried this but this way slightly different ok .
    But make sure you keep button SUBTOTAL pressed down untill it bleeps then make sure you turn the key backwards to reg position.
    Let me know the outcome of this hopefully were getting close to the problem now, i hope
    Also could you tell me if their is a till roll in the till
    Ok bare with me ok few minutes
    Turn key to P position
    Remove ribbon from till
    Turn off till, and turn back on.
    let me know out come ok
    hi on the positions that say 0.00 do any other keys work.
    Whilst waiting for reply ill have another look for you.
    At least were getting their slowly
    Closed means that the tills closed and waiting for some one to log in have you tried pressing a b c or d in top right corner. let me know the out come ok
    Just try signing in as you normally would then let me know ok
    no worrys mate but please remember to rate fixya glad to help you.
    I told you wed get their in the end.
  • paul proctor Mar 30, 2008
    Cheers mate thanks alot glad its sorted, remember the site next time you need help.
    Thanks again for rating
    bye
    Genius:
  • 3,587 Answers
My understanding is that this machine needs to have the C button pressed multiple times, with the key set to control.
  • 790 Answers
Hello smid ,
Have u tried resetting the system using your manual ??
My register is frozen and there is a half of what looks like an E on left side
About 3,390 results (0.88 seconds) Search Results
    How to fix a sharp ER-A330 frozen cash register?
    howtomendit.com > Office Appliances, Cash Registers
    ... to fix anything. Free repair help - sharp era330 frozen cash register. ... my cash register is in calculation mode how do I get out of this mode yvette. November ...
    I have a sharp er-a330 cash regester that locked up on me.
    www.justanswer.com > Printers
    I have a sharp er-a330 cash regester that locked up on me. how can I reset it so it will... Error code L on a Sharp cash register is not clearly described in any support ...(Only then will I be paid, by deduction of my share from the funds already ...
    Sharp ER-A330 Cash Register programming help and tips
    www.cashregisterhelp.com/Sharp/a330pro.html
    Sharp ER-A330 Cash Register Tax Programming ... My preference is to programSharp Cash Registers using the Job-Code Based Programming rather then the ...
    ER-A330 ' Cash Registers ' POS ' SHARP - Sharp Electronics
Jan 31, 2016 | Sharp ER-A330 Cash Register
I can't get the key to turn into the SM mode to clear the grand total history.. I would like to do this before I use the machine
Cash Register Help: SAM4s ER-650 Cash Register
cashregisterhelp.blogspot.com/2008/05/sam4s-er-650-cash-register.html
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
Samsung Cash Registers ' ER650 Bar Code Scanner ...
www.maxperience.com > ... > Cash Registers
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at http://www.cashregisterguys.com and if you are looking for ...
Samsung Cash Registers ' Samsung ER 650 Deleting PLUs ...
Dec 01, 2015 | Samsung SAM4s ER-650 Cash Register
Samsung er 4915
Thats an old model. If I remember correctly E1 was a clerk error. Try pressing 1 then clerk in R mode.
Dec 25, 2013 | Samsung Retail Supplies
PLEASE HELP ME TO PROGRAM THIS SAMSUNG ER-4915 CASH REGISTER
get a firmware diskpart a usb stick boot off USB if you can, as I have done a few registers Im thinking it might have a special firmware. As long as you find a OS that supports cash register or a Firmware it shouldnt be that hard to program.
Oct 23, 2013 | Computers & Internet
Samsung er 4940 manual
It means the printer is stuck and cannot drive
Apr 25, 2013 | Sharp XE-A402 Electronic Cash Register
Programming a Samsung ER-5115 Cash Register
My Register was working and all of a sudden it stop working none of the the key reacts. on the display it says " PP 0.00" Whats the best thingh to do?
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
1,454 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
