Question about Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum
I NEED A MOTOR FOR MY HOOVER POWER NOZZLE MOD. NO. S5682 WHERE CAN I CHECK FOR PRICES?
Check Sears.com go to parts . Type in model # or part # this should get you to parts list where you can make your part selection.
Posted on Apr 01, 2008
    President:
  • 1,673 Answers
Part number is 43177062 and will sell for around $80. You will have to just call around to your repair shops, or maybe find one on line.
Posted on Mar 29, 2008
How to open Hoover S3825
Hi there! We recommend taking your cleaner in to a Hoover authorized service center to have the motor replaced or repaired. I have included a link to the service center locator if needed. Hope this helps!
Service Center Locator
Oct 05, 2014 | Hoover Elite Cyclonic Canister Vacuum with...
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
Hoover does not 'hoover' properly
If it has a power nozzle you should replace the belt.
Dec 18, 2013 | Miele Blue Moon Bagged Canister Vacuum
The self propel switch on my Hoover 7500 wind tunnel is intermittent. How can I repair it?
Hi
You'll need to check if belt is disconnected or worn out. To check, disconnect cleaner from electrical outlet and disconnect power nozzle from extension wands. To remove hood, turn nozzle over and unscrew the 4 recessed Phillips head screws. Note: Do not remove the 3 screws in the triangle formation as these hold the motor in place. Please check the video for details--
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Sep 03, 2010 | Hoover U6630-900 WindTunnel Bagless...
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
How do I clean the hoover steam vac floor cleaner machine
Nozzle Clean Out tool is NO LONGER AVAILABLE from Hoover. Hoover stopped making this part over 1 year ago, and it's not sold any more. What you'll need to do is remove the dirty solution thank, unscrew the one silver screw on the suction port of the clear window, then turn the machine upside down and remove the two silver screws on the bottom corners of the see thru window. This will then allow you to completely remove the see thru part to clean inside of it. Unfortunately with this model that's really the easiest way to do it now that the tool is no longer available.
Apr 18, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The bottom of the hoover wont work. its not picking anything up and not spinning round.
You most likely will need to replace the belt on this model. There are 4 screws in the corners of the bottom power nozzle. DO NOT remove the 3 that are grouped together (these are the motor screws). once the top is removed then remove 3 roller cover screws. replce belt and reassemble in reverse order.
Oct 28, 2009 | Hoover S3639 WindTunnel Bagged Canister...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum Logo
76 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
